Cutting holes in copper
Home Forums Beginners questions Cutting holes in copper
  • #544097
    Peter Simpson 1
      @petersimpson1
      I need to cut two 1inch diameter holes in 1/8th copper sheet. I was thinking of using a step drill up to 22 mm then using a boring head to complete the job. Is there a better way ?
      Peter Simpson 1
        @petersimpson1
        #544100
        Ian P
          @ianp
          'Better' depends on circumstances and what equipment is available.
          Your step drill followed by boring sounds good. Fly press and punch would be another way.
          Ian P
          #544101
          Martin Kyte
            @martinkyte99762
            Brad point drills work well in copper. Nothing wrong with the boring head idea.
            regards Martin
            #544105
            Clive Brown 1
              @clivebrown1
              Chain drilling and a half-round file
              #544110
              noel shelley
                @noelshelley55608
                3/4"Wedon shank 1"rotabroach. A 2MT holder in a drilling machine. You then can do holes from 11mm up to about 1 1/2" with ease. You do need slow speed though. Noel.
                #544112
                not done it yet
                  @notdoneityet
                  To what precision? A tank cutter is likely a possible approach? I’ve got various q-max tank cutters. They are only rated to 2mm but i’ve used them on thicker stuff … they don’t say whether hard or annealed copper
                  #544150
                  JA
                    @ja
                    Although the copper may be a bit thick I would consider using a piercing saw with a thin blade (less metal to remove). You will break blades but that is to be expected. Finish off with a small half round, or round, file ideally one that has no been used on steel.
                    I have happily cut 1/8" thick brass with a piercing saw and made 1/32" thick copper gaskets using the above method.
                    JA
                    #544155
                    bernard towers
                      @bernardtowers37738
                      What’s wrong with a 1 inch step drill?
                      #544156
                      noel shelley
                        @noelshelley55608
                        A sharp Q-max cutter would do it. The Deluxe version has a hollow hydraulic cylinder That develops about 5Ton pull – easy to use on the bigger sizes ! Where are you ? Noel.
                        #544282
                        Tim Stevens
                          @timstevens64731
                          I would use a piercing saw followed by a fine (fairly new) half-round file. Depending, of course on how critical the roundness is, as well as the measured diameter.
                          Cheers, Tim
                          #544290
                          Mark P.
                            @markp
                            How about clamping it between two pieces of plywood and using a hole saw?
                            Mark P.
