Alex,
Almost all materials require it’s own sort of cutting agent, but you can’t go far wrong if you buy yourself a bottle of cutting and tapping fluid.
You don’t need to flood the whole area with it, just a light coating will do.
It is designed to take the high pressures involved with tapping and very heavy cutting, but it is just as good for reaming and drilling.
For the average amount a person does in the shop, a bottle can easily last a couple of years, so doesn’t work out too expensive when spread over that time, and of course it will do you for the other jobs as well.
Hope this helps
Bogs
