cutting copper
cutting copper
Home Forums Beginners questions cutting copper
  • #41828
    david simmo
      @davidsimmo
       hi as you can see Iam new to model engineering,I would like to buy some tools for cutting copper 16 gauge ,and would like advice on the best tools for the job in hand the manufacturer all say there is best . in the past I asked
       the me forum and got so good answer thanks dave ps having truble  wih pc
       hope to get it fix today
      david simmo
        @davidsimmo
        16 gauge
        #41837
          If its simply cutting to size then a fine toothed hacksaw say 32tpi will do. It can help to sandwich the plate between scraps of ply or MDF to reduce the risk of teh blade catching.
          To finish the edge then a decent sharp second cut file will do
          What are you making as it will give a better idea of what type of cutting is required.
          Jason
          #41862
          John Wood1
            @johnwood1
            I use a device called a ‘Goscut’ Basically it comprises a handle/frame with a flat metal rail at the top (horizontal) which has a slot along its length, a blade fits within this slot and the flat material is placed on the top rail and is cut with the blade which hinges from below. Because the rail has two sides the metal is kept flat. I can’t remember the make, was it Eclipse? but I don’t think they are available now. I still pick up the odd one at car boot sales.  Back a bit was the ‘Nibbler’ tool which was popular and widely advertised in ME but I don’t think they are available either. Someone must produce something these days, I just thought a couple of names might give you a lead though.
            Circlip
              @circlip
              “Monadex” John??  In the same vien “Hens Teeth” nowadays.
                    Regards  Ian.
