Cutting Bevel Gears
Cutting Bevel Gears
Home Forums Workshop Techniques Cutting Bevel Gears
Viewing 25 posts - 1 through 25 (of 37 total)
  • #15467
    Engine Builder
      @enginebuilder
      Engine Builder
        @enginebuilder
        Does anyone have details of the calculations for cutting constant depth bevel gears using standard involute gear cutters. I have actually cut gears before using this method using details in a borrowed book but I no longer have acess to it. Ivan Law doesn’t help much in his book and only describes mitre gears, I am looking for the calculations needed when the gears are diifferent sizes.
        #51085
        macmarch
          @macmarch
          Hi Engine Builder,
          Daval Gears will, if asked nicely send you a cat of “Metric Drive Components”
          It contains all you could possibly wish to know about gears. They can be contacted on 01707 283131
          #51086
          Steve Garnett
            @stevegarnett62550
            It’s just possible that all you need to know is in this PDF
            #51088
            Engine Builder
              @enginebuilder
              Thank you macmarch. I already have this book but had forgotten I had it !
              Thank you Steve. Details of cutting your own gears are given but refer to the special bevel gear cutters not regular involute ones like Ivan Law describes.
              #51089
              macmarch
                @macmarch
                Out of interest, has anyone been able to get a copy of Haroaki’s (not sure of the spelling) book on building Shay type loco’s where he descibes how to cut spiral bevel gears on small home equipment?   I have tried the local library but to no avail. I would find £60 for the book for a few pages somewhat  excesssive.
                #51091
                DMB
                  @dmb
                  Hi macmarch,
                  I bet someone, somewhere, is flogging that book on ebay for much less than £60. Give it a try.
                  John.
                  #51093
                  Owen
                    @owen
                    I have both of Kozo Hiraoaka’s Shay books and I just looked at them. In both casess he uses stock gears and reworks them to suit. Perhaps it is the Climax book,I don’t have that one.
                    #51102
                    Terryd
                      @terryd72465
                      Off thread slightly but perhaps of historical interest for many of us there is a delightful and very readable book on change wheels for thread cutting on the lathe.  It has the very Edwardian style of catchy title i.e.
                      “The Calculation of Gear Wheels for Screw Cutting Lathes”.  By a Mr D de Vries
                      It is available as an archive resource which is all the better for being free, here:
                      Sorry to go OT but thought you may like it
                      Terry
                      Edited By Terryd on 25/04/2010 06:58:52
                      Edited By David Clark 1 on 26/04/2010 11:25:41
                      #51103
                      Terryd
                        @terryd72465
                        Posted by John Coleman 1 on 24/04/2010 22:39:12:
                        Hi macmarch,
                        John.
                         Hi John,
                        The cheapest I could find the Kiraoka’ book on the Shay was in the US at £43 including delivery.  The one eBay example, also in the Stated was £29 +£22 delivery to the UK (yes Pounds not Dollars)
                        Terry
                        #51108
                        Paul White 3
                          @paulwhite3
                          Hi, it is in the climax book. Have the book, cut the gears, very satisfying.
                          Can I help?
                          Paul.
                          #51109
                          John Stevenson 1
                            @johnstevenson1
                            How to cheat !!
                            John S.
                            #51110
                            Paul White 3
                              @paulwhite3
                              The other matter I meant to mention is the article on cutting constant depth bevel gears that apeared in model engineer  15Nov 64 , this should help.
                              Paul.
                              #51111
                              Engine Builder
                                @enginebuilder
                                Thank you for the ref, Paul.
                                I have a vast collection of ME’s but sadly only one issue from 1964 and its not that one!.
                                Can anyone scan a copy and email it?
                                #51116
                                Peter G. Shaw
                                  @peterg-shaw75338
                                  I have found references to making bevel gears in the following:
                                  ME Peter Foyle (20.07.97) & Dave Lammas (10.10.97).
                                  MEW88 & 92 (Feb 03 onwards) Brian Perkins & Jim Whetren MEW 31 (possibly Sep 95 or thereabouts)
                                  At least one of these, the Lammas one I think, is concerned with parallel depth gears.
                                  Peter G. Shaw
                                   OK edit no. 1!
                                  Abort the Dave Lammas comment. Iwas thinking of an article by G. Tardrew in ME 18 July 1986 titled Parallel Depth Bevel Gears. The article contains descriptions and calculations.
                                  Edited By Peter G. Shaw on 25/04/2010 13:40:51
                                  #51118
                                  Engine Builder
                                    @enginebuilder
                                    Thank for your trouble Peter. I have all the issues you mention and will seek them out.
                                    #51122
                                    Engine Builder
                                      @enginebuilder
                                      Peter, I have found the Brian Perkins article and this is the most helpful. He explains the calulations in a manner I can understand and points out an error in th Ivan Law book. I can calclate the gears now, many thanks.
                                      #51129
                                      Peter G. Shaw
                                        @peterg-shaw75338
                                        Glad to have been of help.
                                        Good luck with your cutting.
                                        Peter G. Shaw
                                        #51136
                                        macmarch
                                          @macmarch
                                          Hi All,
                                          Thankyou for the info.  Paul White 3 perhaps you can help, ccan you contact me? (my profile).
                                          cheers all
                                          Ray
                                          #51137
                                          NEIL SMITH 1
                                            @neilsmith1
                                            I cut the differential bevels for my 3″ scale Fowler using the parallel depth method,and found the Lammas information to be the most usefull,better than the Law book (imho).The gears meshed surprisingly well. Regards Neil.
                                            #51201
                                            Sub Mandrel
                                              @submandrel
                                              What is the error Brian Perkins found? I have cut about eight bevel gears using Ivan Law’s method without problems, all quite small.
                                              Out of curiosity has anyone made a Eureka? I have some 2 1/2″ EN1A and some 1 1/2″ silver steel ready, but he specs EN8. Would EN1A cope (I might only make a couple of cutters a year).
                                              Edited By Stub Mandrel on 27/04/2010 21:24:17
                                              #51203
                                              Engine Builder
                                                @enginebuilder
                                                Hi Neil
                                                Brian Perkins reccons there is a misprint in the formula for calculating the small end dia. If the mating bevels are the same size, ie mitre gears, the error does not affect the calculation.
                                                #51206
                                                Sub Mandrel
                                                  @submandrel
                                                  Thanks EB; all mine have been matched pairs. I’ll make a note in the book.
                                                  I made a mistake on the Z-height for one of a few mm and ended up with a skew gear – surprisingly it meshes fine with an ordinary gear, although I haven’t used it.
                                                  Francois Meunier
                                                    @francoismeunier96697
                                                    Hi
                                                    The error in the I. law book is on fig. 80, p106, the formula shows sin instead of cos. As long as the angle is near of 45°, the error is minimal, the gears would run, However for a different angle as in the case of as of a ratio 2/3  (33 and 56&#176 the error will be too great.
                                                    The paper of B. Perkins helped me so much, it ‘s really a must before cutting bevel  gears.
                                                    FMM
                                                    #51211
                                                    John Stevenson 1
                                                      @johnstevenson1
                                                      Posted by Stub Mandrel on 27/04/2010 21:22:36:
                                                      Yes, I have made one but scaled it up for full sized 1″ cutters. I made mine out of bright flat but has it all professionally cyanide hardened, works very well and has made many special shaped cutters on it.
                                                      Ironically I have never made a gear cutter on it
                                                      John S.
