Hi Stewart
As some of the other contributors have said a useful starting reference
would be the Quorn book.This 45 deg angle would be more about the
lead required to obtain this angle at a given diameter .Some photo's
posted in the album "Helix" will show in photo 1 some guide hobs
made by these methods ,the sizes indicate the cutter diameter ,the cutters
all have a nominal 30 deg helix angle. As can be seen when all viewed as a
common diameter they all look very different ,the 1/16 inch one is only
two start the other two are four start.
In the second photo is the gear change quadrant for the Myford made to cut
these guide hobs,since there is no indication on the diameter turbine
blade /wheel some indication of the ratio needed between the leadscrew to
headstock to get 45 deg at a typical model size turbine of 60 mm nominal
diameter would be about 60 to 1 .
There are other complications when making these sort of forms in this way,
Using a toolpost milling atachment and just offsetting will result in producing
a tombstone effect on the blade ,the blade will be undercut at the root and
thick at the tip to avoid this some adjustment to offset and also rotation of the job is
needed to correct.Sometimes these sort of jobs look at first quite easy to
do and can be much more difficult to end up with the desired result.
The third photo shows this 718 inconel turbine wheel milled from a
solid blank,to do this required a considerable number of fixtures and a
rotary table .
The fourth photo shows a model compressor wheel made from HE 15
aluminium milled on the Dore Westbury using 4 axis cnc ,usually these
are done on 5 axis type machines ,probably beyond the pockets of
most model engineers.
I find it easier to use this prototyping wax for test cuts it can be saved and
remelted for re-use saving metal and tooling as can be seen here with
this nozzle guide vane part in photo 5.
Interested to see how this works out.
