Posted by Ady1 on 06/04/2017 00:35:09:
What we really need is an adaptor which turns an angle grinder into a circular saw for steel
There are stands that turn the smaller angle grinders into a mini chop saw for around £20.00, I bought mine from Aldi a few years back, but they are available from other sources, this picture shows it cutting 8mm studding and 8mm stainless round bar for a 3D printer.
I have an Evolution Rage2 that I picked up on the bay for £60.00 second hand, still with plenty of life left in it, I last used this to remove about 1.5-2mm from the end of a 20x80mm aluminium extrusion, for my laser cutter, that was ever so slightly too long – perfectly square cut and hardly any burrs, I would not even consider trying this on my bandsaw.
For cutting holes in stuff, depending on thickness of material and the shape I am trying to cut , I picked up a second hand Miller Spectrum 300 plasma cuttter for £200.00 at an auto jumble – no-one else seemed to know what it was. Alternatively I can use my 9" or 5" angle grinders freehand, then I have a 3" air cut-off saw, that cost about £20.00 at some car show, a pack of disks for this are about £7.00 for 25, or if you want to go really small, then I have a Dremel.
Mike Cox also references a mini 110mm Rage style saw for about £30.00 from Aldi that he has used to cut 8mm sheet steel.
Plenty of options for the OP to consider.
Edited By Zebethyal on 06/04/2017 08:43:30
