Hi
I've just become the proud owner of a single lip cutter grinder by GH Alexander and my question is what is the difference in the make up of the machnie between a single and a multiple lip unit.
I should add that i understand what the different machines are for, put simply the single lip device can be used to grind for example the end of a scriber or a twist drill (using an added attachment), while a multiple unit can be used for milling cutters.
What I can't seem to visualize is why a single lip cutter can't be made to re-grind say a four tooth milling cutter?
What would I need to do to add an attachment to my single lip cutter to enable me to re-grind milling cutters?
What are the chances of acquiring additional collets? Do these have a special part number? If so any ideas what this would be? If I made some would free cutting mild steel be adequate?
Finally how would I go about producing a collet with a squate hole, for holding HSS lathe tools?
Many thanks
