Posted by not done it yet on 26/06/2023 08:50:34:
It would be the $20K (note upper case ‘k&rsquo
ridiculous price tag placed on that rod in the video hype.- unless it is to some aeronautical standard – that would put me off bothering to watch that. Even so, if it needed ‘saving’, would it still be to the prescribed acceptable standard?
I often think Model Engineers should be sent on a Management Accountancy course to learn it's about value rather than price. Value is is some combination of cost, benefit, and time. Price is obviously important, but it's far from being the only factor.
Whilst price dominates decision making In ordinary life, and many small businesses are successfully run the same way, there's a point at which other considerations come into play. A relative encountered this painfully: he ran a small-business, which he enjoyed thoroughly leading from the front, him and a couple of mates. After the business grew to employ about 15 people, he hated it! Rather than doing the practical work he enjoyed, he found himself managing people, money and assets, all of which were much harder to do than he'd imagined, plus lots of responsibility, and all the aggro. Tragic, but in a business beyond a certain point, the need to manage people, money and assets mean the financial game is often played to different rules. What's worth the money, has to take more than price into account.
In that context, I spent £427 last week buying not very much metal. (Anyone who hasn't bought Brass recently is in for a shock!) Not a sound business decision, but I enjoy Model Engineering, and the metal will keep me amused for at least a year, I hope! Not everyone would have made the same purchase.
Back to mending earth movers, part of the cost of a repair is off-set by the cost of downtime. Machines that work of a living out of action for a few months whilst parts are shipped from the US or Japan cost a fortune, making local repair an option even if repair costs more than a new part. Time is money. Judging by the videos, it appears repairs are about half replacement price, and the work is done quickly compared with importing from abroad. $20000 dollars Australian is a mere £10000.
I've learned a good deal about Hydraulic rams from the videos. They're a mix of high and low-tech. Outside the cylinder, simple and chunky parts are highly stressed with cheap bits designed to break before anything more expensive. Bearings, pins, eyes and end parts all take a hammering, either broken off, bent or badly worn. There's much scope for repairing the chunky parts with a big lathe, big milling machine, big hydraulic press, and lots of skilled welding. Inside the cylinder, the piston and seals aren't too difficult, but the aforementioned damage can make it very difficult to get inside. Changing worn out piston seals – easy on a bench – might start by chopping the ends off to gain access and then welding the whole lot back together again.
Hydraulic cylinders and rods aren't made of ordinary mild-steel. Cylinder steel arrives pre-bored, skived and honed to size. Piston rod is delivered accurately ground to outside diameter. Both are induction hardened up to a depth of about 10mm. Not cheap.
If they have to be replaced, they're machined as necessary to fit the end-parts. Getting through the induction hardening is fun, and after machining the end-parts are then welded on. Not seen a video where either a critically damaged rod or internal cylinder surface is repaired. I guess that's too difficult.
The most accurate work seems to be making pistons. They're turned to a diameter, I guess about 0.05mm, but then grooved to take the O-rings and other seals. The grooves are cut micrometer accurately. Some of the milling is accurate, but much isn't, 0.05mm rather than 0.01mm.
I'm not sure what the 'prescribed standard' is. The parts being mended are treated very roughly and aren't safety critical. I think the only requirement is that repairs last long enough to cover the cost of doing it, plus a margin.
I recommend watching the videos.
