Cup wheel for finish grinding mild steel
Home Forums Manual machine tools Cup wheel for finish grinding mild steel
  • #46796
    Peter Bell
      @peterbell11509
      I have a number of flat head mild steel screws to finish. I thought it would speed things up a bit if I mounted them in the wheel head unit to grind on my Jones & Shipman T&C grinder. The setup works fine but I cannot get a decent finish with the grinding wheels I have.
      Not very experienced with grinding so have been reading the books (always dangerous!) and it looks like I need A320 grade, all mine seem to be 60, Anyone have any ideas where to get a suitable cup wheel 31.75 bore, or will a diamond do the job without breaking the bank?
      Thanks  Peter
      Peter Bell
        @peterbell11509
        #46809
        Frank Dolman
          @frankdolman72357
                 Grinding steel, or anything containing iron, will destroy a diamond
           wheel, unless you take it paralytically slowly.
          #46822
          Circlip
            @circlip
            The surface finish of mild steel after grinding is usually c-rap unless you use a coolant in copious amounts and naff all cut on the wheel.
              Regards  Ian.
