Posted by Jeff Dayman on 21/01/2019 00:25:13:
Posted by John Reese on 20/01/2019 19:08:49:
Posted by vintage engineer on 20/01/2019 15:00:41:
It's caused by hydrogen embrittlement. A naughty trick foundries do on aluminium castings is to add zinc to bulk out the aluminium. This comes to light when you try to weld the crap!
Fraid not. It is lead contamination that causes the zinc rot.
Hi John, Not challenging what you say, just searching for documentation. Have you any metallurgical documentation for the effect of lead in these expanding die castings? …
Always a problem laying hands on Mother Lode documentation because access is often via a University Library or has to be paid for!
However the Wikipedia Zinc Rot Article references a Dutch NLR paper 'Corrosion-induced cracking of model train zinc-aluminium die castings', which is available on the Wayback Machine as a PDF. (It's in English.)
Couple of quotes from the Report:
'The corrosion results from impurities in the metal, and requires the presence of moisture.'
'The problem needs thorough discussion because information available to the non-specialist, notably via the internet, often contains errors.'
'The origin of zinc die castings is a bit uncertain. Bierbaum (1923) mentions zinc-copper-aluminium die castings made as early as 1896, while Goodway (1985) and Gross (2003) state that the first commercial alloy was produced around 1907. By the early 1920s it was recognised that alloys based on the zinc-aluminium binary system were easy to cast and had good mechanical properties. At the same time, it became clear that the control of impurity elements was vital: small amounts of lead, cadmium and tin resulted in corrosion-induced cracking and swelling of the castings (Brauer and Pierce 1923).'
'Some alleviation of the corrosion problem was obtained by additions of copper to the impure binary alloys (Brauer and Pierce 1923), but its elimination was achieved only by the use of special high purity zinc (99.99%) and further additions of small amounts of magnesium (Goodway 1985; Gross 2003). These developments took place during 1926-1929, leading to introduction of the ZAMAK1 series of alloys, several of which are still in use today…'
The NLP report lists 11 references, the most recent being 'Gross, D.K., 2003, Zinc Die Castings – The Importance of Alloy Chemistry, Die Casting Engineer, Vol. 47, No. 2, pp. 30-31.'
The report goes into a lot more detail.
I'd add the observation that Zinc occurs naturally in ores containing Lead and Cadmium and refining it isn't easy. As Die Casting is often done for cheapness, it is rather likely that the alloy used for limited-life items might not be the best. It's also possible that a die caster might not consistently maintain absolute cleanliness throughout a series of melts, and there's always a risk of a numpty cutting corners or even chucking incompatible scrap into the mix…
