Cross slide travel
Cross slide travel
Home Forums Beginners questions Cross slide travel
  • #11298
    Chris Murphy
      @chrismurphy94983
      Chris Murphy
        @chrismurphy94983
        Hi all,
        I have a Myford ml7 and the problem I seem to be having at the moment is that when facing off or parting off, it does the job but the cross slide seems to get very tight when getting to the centre pip.
        what id like to ask is if your an ml7 owner how much travel do you get and also does it start to get very tight when your almost at centre.
        how far is the cross slide supposed to travel past the work you are cutting.
        any ideas or suggestions as to why this would be happening on my lathe.
        the cross slide is the long length one by the way.
        Thanks
        chris m…..
        #611910
          Sounds more like you may have a tool height issue, does it travel OK when the tool is just clear of the face of the work or does it become tight all the time in which case gibs may need adjustment on a worn cross slide dovetail.
          #611914
          not done it yet
            @notdoneityet
            The cutter should be adjusted to avoid a centre pip. Actually, for making heavy cuts on larger diameter bars, the cutter will be deflected to below centre height by an amount depending on how rigid your set up happens to be. With an old fymord, I expect it could well be a few thou. There should be no (or minimum) deflection when at the centre of the bar.
            Remember that at the centre, the surface cutting speed is actually zilch.
            If you are using carbide, travelling beyond the centre may cause the cutter surface to be damaged (by reversing the cutter direction).
            #611915
            bernard towers
              @bernardtowers37738
              Yes with you there Jason, sounds like it’s too high.
              #611917
              Roderick Jenkins
                @roderickjenkins93242
                Might also be worth checking that the cross slide end plate isn't misaligned. A problem I had when removing the lead screw to use the taper turning attachment and the re-installing it.
                Rod
                #611919
                Chris Murphy
                  @chrismurphy94983
                  Hi,
                  the cross slide moves along fine, but as I’m getting nearer the centre of the work I becomes very tight.
                  any other ideas.
                  thanks
                  chris m….
                  #611920
                    So it moves fine when you are not cutting even when moved as far across the lathe?
                    If so look at tool height particularly if it is leaving a conical bump in the middle as tool is too high
                    #611921
                    Andrew Tinsley
                      @andrewtinsley63637
                      This always happens on my set up. The parting tool is correctly positioned.I never have a pip after parting off, but you need to use more force to cut the pip off. I always put this down to the almost zero cutting speed on the last bit of the cut.
                      Andrew.
                      #611926
                      Chris Murphy
                        @chrismurphy94983
                        Hi,
                        even when I’m not cutting and moving the cross slide it still gets very tight at the same point.
                        the cutting tool is level to the centre and cuts well leaving hardly any pip, but as I said it’s very hard to turn at about this point.
                        thanks
                        chris m…..
                        #611927
                          In that case gibs of what Rod said. I would think you could remove the leadscrew so the slide can be moved back and forth by hand, this will show if it's the gibs getting tight. If it moves freely then the screw position or nut may be the problem.
                          I'll leave it to a Myford owner to suggest how to do this
                          #611960
                          Peter Sansom
                            @petersansom44767
                            Disconnect the end plate from the cross slide. remove the Cross slide screw fully from the lathe.
                            Push the cross slide back and forward. If it is tight at any point then adjust the gibs on the cross slide so it slides easily. Make sure that you have properly lubricated the cross slide with a suitable lubricant, I use an MDS grease.
                            When you reassemble the end plate with the screw back to the cross slide only tighten the 2 end plate screws when you the cross slide screw in ad far as it will go.
                            Only when you are certain that the cross slide is moving freely then try cutting and see if you still have the issue then we know you are dealing with a tooling or cutting issue.
                            Peter
                            #611961
                            mgnbuk
                              @mgnbuk
                              The proper lubricant for a cross slide is slideway oil – NEVER use grease in this application.
                              Nigel B.
                              #611965
                              Howard Lewis
                                @howardlewis46836
                                If the tool is on centre height, it may be that (very likely in an older machine, ) the Saddle and Cross Slide, and probably the Leadscrew,  are worn, and although the gibs are set for the worn areas, things tighten up over the less worn parts.
                                This can be alleviated by scraping the dovetails, but as a newbie, you would be well advised not to do it, for fear of doing more harm than good.   Scraping surfaces, particularly dovetails, is not easy.  It is a hard to acquire skill.
                                Edited By Howard Lewis on 01/09/2022 14:45:53
                                #611968
                                  Howard have you ignored what the OP said
                                  "even when I’m not cutting and moving the cross slide it still gets very tight "
                                  #611970
                                  Howard Lewis
                                    @howardlewis46836
                                    Jason,
                                    I don't think so!
                                    I thought that I took account of that by saying, in the first paragraph, that If there is wear in those components, and the gibs are set for that wear, things will get tight when the less worn areas make contact.
                                    The problem with living with that state is that the Leadscrew and the Mazak nut are likely to wear.
                                    At least a worn nut is easily replaced!
                                    #611971
                                      Howard I was going by what you said in your unedited reply
                                      #611978
                                      Howard Lewis
                                        @howardlewis46836
                                        Jason, Ah!
                                        In that case, your response was valid.
                                        Then I realised what had been sent about not cutting, and the tool now being on centre height.
