Cross Slide Rotary Encoder
Home Forums Electronics in the Workshop Cross Slide Rotary Encoder
Viewing 13 posts - 51 through 63 (of 63 total)
  • #622714
      Posted by Speedy Builder5 on 26/11/2022 10:30:45:
      I had a quick scout around to see what the angular error might be, but didn't find anything on the net.
      The joint is not exactly the same, but for a reasonable approximation have a look at the velocity analysis for a Hooke joint … Loads of examples available, in writing or video, because it’s classic text-book stuff.
      If you read between the lines, it’s obvious [because time remains constant] that the error is angular.
      blowlamp
        @blowlamp
        If a coupling ever does gives up the ghost, then you'd probably get away with a piece of decent rubber/plastic hose, for the amount of torque needed to move the encoder.
        Martin.
        #622718
        blowlamp
          @blowlamp
          Posted by Michael Gilligan on 26/11/2022 12:25:00:
          … but for a reasonable approximation have a look at the velocity analysis for a Hooke joint … Loads of examples available, in writing or video, because it’s classic text-book stuff…
          I don't think the two couplings are comparable with regard to their angular velocity characteristics. The in-line couplings are much more of a constant velocity arrangement than a Hooke's joint, The in-line drive coupling basically being a torsionally stiff coil spring.
          Martin..
          #622721
            Perhaps we could have a forum-poll on that, Martin
            … I remain convinced that it’s a ‘reasonable approximation’
            Let’s see if anyone other than we two is prepared to opine
            Ex contributor
              @mgnbuk
              At a previous employment, we used Huco couplings for connecting encoders to servomotors & ballscrews on CNC machines – more reliable than the type shown, which always broke due to metal fatigue unless the shafts were in very close alignment .
              Very low backlash at the low torques required for encoders at "normal" line counts, I only had issues on a high line count direct mount rotary table encoder, which showed in the reqion of 0.009 degrees wind-up / backlash – not good on a 0.001 degree resolution RT & cured by fitting a special Heidenhain coupling that cost 10 x as much as the Huco.
              Nigel B.
              #622726
              John Haine
                @johnhaine32865
                I was going to mention here that years back one could buy a little board from the US with a 400 steps/rev stepper motor that would act as an encoder – at the time a cheaper solution than a proper encoder. Now I see that you can get these optical encoders from Aliexpress at about £15 delivered so no need!
                Or of course use one of the nice magnetic ones that Joe Noci recently described here.
                #622741
                Speedy Builder5
                  @speedybuilder5
                  Michael, I did buy a pair of Hooke joints, but there was so much backlash in them that it wasn't worth installing them. Hooke joints have poor angular velocity variations. Its interesting that the MINI used to have 1 x Hooke joint and 1 x CV joint – I wonder how that worked out !
                  I did have 1 x beam joint of a far superior quality, but I needed 2! The ones I have are several magnitudes stiffer !
                  This looks like the Rolls Royce Beam couplings
                  https://www.ruland.com/technical-resources/application-spotlights/encoder-applications/beam-couplings-for-encoder-feedback-systems
                  #622747
                    Posted by Speedy Builder5 on 26/11/2022 15:45:29:
                    and as previously stated, I believe that the couplings that you have used will be seen to have what is essentially the same geometry. [backlash being a separate issue, down to quality of manufacture]
                    … Martin disagrees with my ‘analysis’
                    Edit: __ I may have to admit defeat !
                    These little beauties specifically claim to be Constant Velocity:
                    https://www.abssac.co.uk/uploads/docs/gdxfl6e8_Make_your_part_flexible_Catalogue.pdf
                    See the text on page_5
                    Edited By Michael Gilligan on 26/11/2022 16:13:13
                    #622756
                    Ian P
                      @ianp
                      I worked for a company (45+ years ago) who were the UK agents for some USA manufactured welded bellows. We used their bellows shaft coupling on one of our products but changed to Abssac helical beam for cost reasons. We never had any failures and I have every confidence in their products however this quote is from the Abssac datasheet Michael linked to (on page 5) which I do not fully understand.
                      'Torsional variations, which can induce differences in hub-to-hub velocity when subjected to dynamic loading, are minimal in steady-state applications of the HELICAL Flexure'
                      It mentions torsional variations but then refers to steady state. If its steady state then where do the dynamic loadings come from?
                      Just curious
                      Ian P
                      #622757
                      Ian P
                        @ianp
                        Just curious
                        Ian P
                        #622758
                        Ian P
                          @ianp
                          My first (I think) double post on here.
                          I did nothing different to what I normally do!
                          Ian P
                          #622770
                          blowlamp
                            @blowlamp
                            Bob.
                            It was a (very stiff) rubber/metal bonded kind of U/J that was located next to the gearbox and because of that, it didn't need to flex very far with suspension & steering movement, when compared to the C/V joint, which was mounted on the streered wheel hub.
                            Martin.
                            #622775
                              Posted by Ian P on 26/11/2022 16:43:50:
                              Just curious
                              Ian P
                              I think they are admitting that the spiral will wind-up [or unwind] with dynamic changes … and their ‘steady state’ reference is to the shaft running at constant speed.
