0.33mm (0.00129" ) is not an unusual backlash in a even a moderately used machine. I live with a machine with 0.020" backlash, without much problem.
As has already been said, you retract by more than the backlash, half a turn to be safe, and then return to the setting that you require. You work within the peculiarities of your particular machine. Make yourself familiar with your machine, and the controls, and how they affect its operation.
If you are new to the hobby, and machines, join a Model Engineering club where you will receive help and advice, and learn form contact with more experienced machinists. Continue to read this Forum and ask questions, you will learn a lot.
You will be amazed by the work that people do on quite modest machines.
Emojis!!!!!!!!!!!!!!
Edited By Howard Lewis on 24/04/2019 09:46:37
