just want to share with you a quick little project involving a table for dollhouse or a small project that only took me about a half-hour from start to finish. I had started with the normal 3 mm thickness wood that I bought at the hobby shop downtown and completely milled the entire project with a 1 mm diameter tool. this was nothing special but in the Badog software I had to use arcs and circles which slowed me down a little bit.
here is an image of the machine cutting the pieces with a 1 mm diameter mill bit and you can’t really see but I decided to use the mill but that you normally used for drilling PCB circuits in the beginning. this led to cut that was rough and the edges pretty approximate. so the second cut I decided to switch to the normal mill that a used in the other posts that are on the site.
assembly process
Article Link and downloadable file
