Posted by Tony Pratt 1 on 17/04/2023 16:56:17:
Posted by Rowan Sylvester-Bradley on 17/04/2023 15:10:53:
Yes, but I still need to drill small holes 30mm deep, and the problem of the drill wandering and not ending up in the correct position remains. I am gravitating towards milling the basic hole, and squaring up the corners with a specially ground cold chisel.
Rowan
Who says you have to drill small holes, 4/5 mm drilled hole should be fairly doable?
Tony
Yes, indeed. Rule of thumb, a twist drill will stay straight for 5x diameter, so 30mm deep calls for a 6mm drill. Actual size (10 x 20 with 6mm corners, the result looks like this:
![sqholes.jpg sqholes.jpg](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
An advantage of oversized corner holes is they only have to be straight enough to accommodate the male corners, that is not critical at all. So safe enough to drill 5mm corner holes 6x deep, or even 4mm 7.5x deep. Beyond that, keeping a twist drill straight becomes ever more difficult.
As to cutting the hole, I would remove most of the metal by chain drilling, probably with a 9 mm drill, then mill a 10mm wide slot, before finishing the corners with a 6mm two-flute. (same diameter as the corner holes). Chain drilling saves wear on my precious end-mills. As the slot is deep, 6 and 10mm dia end-mills should be used for maximum stiffness – small diameter end-mills are likely to bend, even if long enough. (There's much to be said for chiselling, though it's not very accurate.)
All this assumes big corner holes are acceptable! If not, truly rectangular holes are hard to machine. Through holes are usually broached, but a precision blind hole calls for EDM or lasers.
I do my best to wimp out when faced with difficult machining jobs: with luck a compromise is just as good provided it's strong enough and not plug-ugly in public. Often fixed with paint and putty…
Edited By SillyOldDuffer on 17/04/2023 17:31:46
