Here’s a daft question, I’m putting together an articulated grabber arm for soldering electronics parts and I have made a small base 62mm in diameter, I was going to drill 3 holes at equal intervals around the conical base to bolt it to a metal sheet base plate, when it occurred to me that I could fix some disc magnets to it and make it ‘moveable’.
The thing is I’m not sure what power or size magnets to use, I could experiment but I wondered if anyone had experience of selecting magnets for this application? Some web sites offer small disc magnets with 3kg hold force, if I put three of these on the base I’m not sure if I will be able to move it!
Because I won’t be able to ‘switch it off’ I will need to be able to slide it off. The base will be a sheet of mild steel 1 or 1.5mm thick. I’m not holding heavy objects just chunky electronics components like a potentiometer for instance.
As I type this i suppose I could just glue it :0)
