Unwise to ignore the BS recommendation for use.
Still it isn’t going to wear that quickly, so you could finish the machine, get it into steam and have some fun and then order the 660 bronze. I’ve done the same on my 3″ LS and that’s my plan, and I’m not planning on a new crank! (Nor do I have the slightest intention of calculating the loads, nor of case hardening)
A lot depends on the load in the bearings and the highest load will be imposed by the water feed pump probably, if you are simply doing a bit of light steaming to run it in. Use the injector, shove a bit of proper teflon based grease in there, keep them clean and and keep an eye on them?
I’ll let you know when mine pack up!
If you are really worried get crank and shaft nitrided?
