I attended a lecture at Bristol University by one of the lead designers from TVR. He was talking about the TVR Speed 12, and mentioned that the original homologation rules called for a very low number of cars needing to be produced, so they just fabricated the blocks from welded plate. Then the homologation rules were finalised for the class they were racing in and the numbers were much higher, so rather than redo the design they just built these engines on a production line, out of welded plate…
For those interested, Some other interesting gems came out of that lecture, such as the Speed 12 radiator being part of the space frame (so you basically had to repair it or unweld it…), that they tried running the exhausts down the prop tunnel but realised the diff cooler was going to need to be bigger than the radiator… it was originally going to be a Speed 10 but at the time only Dodge made a 10 cylinder engine and as rivals they were told to poke off when they asked to use their ignition system so TVR made it a 12 cylinder engine instead…
