Crank Diameter
Crank Diameter
Home Forums Stationary engines Crank Diameter
  • #64155
    Alan Worland 1
      @alanworland1
      I am machining the crankshaft for a Stuart Turner No 4 the drawings of which suggest the main bearing and big end diameter is 7/16
      There is plenty of material to come off that I have decided to make these bearing surfaces 0.500 – the main bearings and big end will accomodate the extra.
      Has anybody else done this and might there be a problem I have not thought about?
      Alan Worland 1
        @alanworland1
        #64171
        John Olsen
          @johnolsen79199
          It will not cause any problems, and is a good idea if the engine is likely to do any hard work. The Stuart engines generally are semi-scale, eg they are not scale models of a particular prototype, but are proportioned as if they were. So the journals are smaller than they would be if the engines were intended for hard work.
          regards
        Home Forums Stationary engines Topics
