Thanks for the many pointers, will check out everything.
Not easy to get at the motor pulley [are they ever ! ], but needs must .
I did suspect that the link belt might be the cause and was thinking or reversing it to see if the same thing happened, in reverse, as it were. Clive may be quite right.
To Coggy, I suspect you still have the original belts, so may not have come across this effect. The reason I fitted a link type was because I did not fancy the hassle of removing shafts ect, I tend to leave well enough alone, but I might give it a try. As a matter of interest, link belts are about three times the price of standard belts.
I will check out everything, and again, thanks to all.
