Coventry Die Head
Coventry Die Head
Viewing 21 posts - 1 through 21 (of 21 total)
  • #639283
    Chris Crew
      @chriscrew66644
      After watching the MrCrispin Coventry die head video on YouTube I decided one might be a novel addition to my workshop. I found the items advertised on eBay and put several in my watch list. One was for a job-lot of three for which it stated they all appeared to work and I received an offer price. I was actually going to reject this offer and the items but, being a weak-willed and spineless character, I pressed the accept button. However, I may have to wear the donkey's ears for a couple of weeks because when the items arrived none of them appear work and all of them will need some remedial work to a lesser or greater extent, or so it appears given a cursory 'once-over'.
      So, the questions are these: does anyone have an exploded diagram of one of these devices, is there any company in existence that can supply parts (apart from the chasers which appear to be easily sourced) because I assume these devices have not been manufactured since Alfred Herbert's demise and has anyone else refurbished one of these devices before and could provide some advice?
      I am hoping that I can salvage at least one working die-head from the three almost identical ones that I bought and put the rest down to experience.
      Chris Crew
        @chriscrew66644
        #639288
        Anonymous
          Wiseman Threading Tools do a wide range of spares.
          Wiseman
          #639290
          Rob McSweeney
            @robmcsweeney81205
            "The Book of the Coventry Diehead" has all the info. There is a downloadable version online somewhere.
            #639292
            bernard towers
              @bernardtowers37738
              Best of luck Chris your problems are only just starting, wait till you start collecting die sets,I hate to think how much I spent. Good thing to make for them is the internal stop which is a must when making batches of Bolt/Screws. I have just made a batch of 5mm sq headed bolts and they were threaded at 300rpm and the head clicks off at the came place every time,Magic. Thoroughly recommend the book Rob mentioned.
              Edited By bernard towers on 27/03/2023 17:29:30
              #639293
              noel shelley
                @noelshelley55608
                Hi Chris, What sizes and types have you got ? Rob has mentioned the book, it comes in many editions I think mine is ed 25. Noel.
                #639295
                Chris Crew
                  @chriscrew66644
                  Noel, They were sold as being 1/2", not sure if this is correct as I am new to this type of device and until I acquire the book/manual I have no idea from where this dimension is taken. Many thanks to all for the responses, thus far.
                  #639299
                  Tony Pratt 1
                    @tonypratt1
                    Chris, were they sold as 'working'?, if they don't work send the lot back at the sellers expense.
                    Tony
                    #639301
                    Oldiron
                      @oldiron
                      Chris you have a PM
                      regards
                      #639312
                      Chris Crew
                        @chriscrew66644
                        Posted by Tony Pratt 1 on 27/03/2023 17:53:42:
                        Tony
                        Tony, unfortunately the seller stated 'no returns accepted'. I knew it was punt when I purchased the items, fortunately I elected to use PayPal's 'Pay-in-Three' facility so the financial damage has been spread. At least it has presented me with a challenge to sort out the issues, I actually enjoy repairing and refurbishing bits and pieces so I will now view my purchase as a project.
                        #639315
                        peak4
                          @peak4
                          This Site may have some useful info as well
                          https://www.turbinejon.com/technical-data/
                          Bill
                          #639339
                          bernard towers
                            @bernardtowers37738
                            Usually if its a 1/2' head that's the max size thread dia, although in later years oversize sets were available.
                            #639340
                            Oldiron
                              @oldiron
                              Chris. The seller can say "no returns" but if you report to YT as not as described you can still get a refund.
                              Distant selling regulations apply on YT so goods have to be fit for purpose.
                              regards
                              #639342
                              Chris Crew
                                @chriscrew66644
                                I have actually got one of these things working in a fashion, it was bunged up with old grease and dirt, but the return spring that rotates the 'scrolls' seems very weak although it may be that a stripping down and really thorough clean and lube may improve things. One of the others seems completely 'dead' and the third is in pieces on my bench. At the moment I have no idea how to re-assemble it but someone has been kind enough to send me a PDF of the manual so I am hoping to know a bit more before I go back into the workshop tomorrow. If I can resurrect at least two of them I will make some new levers with plastic knobs to smarten up their appearance. I will also make MrCrispin's clamping sleeve to fit a device to the Myford tail-stock. All good clean fun!
                                #639344
                                Emgee
                                  @emgee
                                  I have a couple of heads, 1/4" and 5/16" sizes, both of them are difficult to use as the dies don't stay closed other than holding the lever in position, doesn't seem to latch as it should.
                                  Any tips most welcome.
                                  Emgee
                                  #639346
                                  peak4
                                    @peak4
                                    Posted by Chris Crew on 27/03/2023 21:04:16:
                                    Which book have you been sent?
                                    There's a 22MB pdf file available readily on line, or a (slightly) higher quality 75MB version, though I can't remember where I found that one offhand.
                                    Both are 95 page documents entitled The Book Of The Coventry Diehead 25th edition.
                                    The link I posted above on Trurbinejon, has some better quality photo essays
                                    Bill
                                    #639347
                                    Chris Crew
                                      @chriscrew66644
                                      Bill, The book I have been sent is the 24th Edition which is a 128 page PDF.
                                      #639353
                                      JohnF
                                        @johnf59703
                                        #639366
                                        Alan Donovan
                                          @alandonovan54394
                                          +1 for Oldiron.
                                          If you choose to ask for a refund, ebay have a complaints/dispute procedure you can use.  Details of how to proceed are on their website.
                                          Edited By Alan Donovan on 28/03/2023 06:58:57
                                          Edited By Alan Donovan on 28/03/2023 07:04:49
                                          Edited By Alan Donovan on 28/03/2023 07:24:18
                                          #639374
                                          Bantam Bill
                                            @bantambill
                                            They are easy to strip down and rebuild, there is a manual available on the interweb. I was given a very rusty seized up 1/2” head, once stripped, cleaned and a few new parts from wiseman it works a treat, you might need to make an adaptor to fit the tailstock.
                                            #639637
                                            William Howcroft
                                              @williamhowcroft68688
