Pete
6" disks would require a totally impractical amount of re-working. Effectively you'd need to cut it right back to the motor assembly and start over. Including making your own tool rest / work table. Might as well start with a bare motor and be done with it.
The carrier disk fitted is quite thin, a touch under 5 mm, with a similar space behind it so there is limited room between the edge of the tool rest / work table and body for a proper grinding wheel or diamond lap disk. Boss appears to be around 35 mm diameter as eyeballed from underneath with the table removed.
I'm going to try it out as is with the paper disks supplied and, if that seems OK, get some finer ones.
Its only rated for 15 minutes use at a time before you have to stop and let it cool down. Its never going to be up to proper TipLap or similar tool standard but should do just fine as the second stage in a three step sharpening process viz :-
1) basic shaped of the periphery of the bench grinder.
2) clean up hollow ground surface left by bench grinder to have small lands "top & bottom" at desired angles.
3) hand finish to bright, sharp, edge with diamond lap or stone.
Clive.
