Sorry guys. Applying a continuous DC voltage of 13.2 "trickle charge" will kill a wet lead acid battery unless its in very good condition or the available current is suitably restricted to match the condition and capacity of the battery. If the charge current is low, essentially very little more than the self discharge rate, and the battery large this can take a very long time but die it will.
If the battery is small, probably somewhat abused and not that well made in the first place i.e. typical motorcycle battery it will almost certainly be dead by the fourth winter on such a regime.
If it were that easy 13.2 V trickle fixed voltage would have become the norm ages ago. Fact is the idea has surfaced at least 4 times for the motorcycle market in my lifetime. Had a certain flurry of interest with folk saying how wonderful it is then died a protracted death as the new wunderkids get a bad reputation for killing batteries. Car batteries are bigger and more robust but again it never really got traction except among the inspector meticulous types who really don't need an auto control charger anyway. Despite theoretically knowing better I've tried a couple myself and commiserated with folk who got no benefit from other varieties. About the only guaranteed way to get the expected life out of a vehicle battery is to use the beast regularly.
Static battery charging and condition maintenance is hard because the chemical shift between electrolyte and plate occurs at millions of semi-independent sites which all need top move pretty much in step. If things go wrong at one or more points the whole balance is upset locally and the cancer spreads. Modern vehicle batteries actually like being shaken up as the vehicle drives along with regular hefty bursts of current when the starter engages. Helps shake up the bits going wrong. Fortunately wet lead acid batteries are a lot more tolerant than lithium ion which run close to the ragged edge under charge, especially fast charge, and are totally dependant on effective condition monitoring to avoid going into bomb mode.
Way back when I was a lowly lab rat at RARDE Elektor magazine published a circuit for one of these battery maintaining chargers. Showed it to my boss who was less than impressed and dropped a massive tome on battery types, maintenance and charging thereof on my desk a few days later. Presumably quite authoritative as it was prepared for MoD who have a natural vested interest in keeping batteries up to the mark on stored and rarely used equipment. Lunchtime reading for the next fortnight (ish). For a while I knew more than any sane person should about the care and feeding of batteries but have always retained a healthy respect for just how difficult it is to always keep all batteries in good condition. A few weeks testing thermal batteries left an indelible impression as to how close a battery under high discharge conditions is to a bomb, or at least fire-lighter!
Clive.
Edited By Clive Foster on 17/10/2016 20:14:25
