Couple of things at Lidl
Home Forums Hints And Tips for model engineers Couple of things at Lidl
Viewing 25 posts - 226 through 250 (of 285 total)
  • #365555
    mark costello 1
      @markcostello1
      Wrap Them up good and store in refrigerator to prolong their life, Yours might shorten slightly.wink
      Muzzer
        @muzzer
        Stick them in the airing cupboard or in / on the boiler to keep them dry. If they are damp, you can put them in the oven at low temp to dry them out. Even better, get a sealed welding rod container.
        #365608
        richardandtracy
          @richardandtracy
          I keep all my sticks in the airing cupboard and stick in the end of a blow torch flame just before using. The arc strikes a bit better when hot.
          Richard.
          #365618
          Ady1
            @ady1
            Helmet is disposable…
            Very disposable indeed, don't even bother using it
            Get an auto darkening one and decent gloves and you're good to go
            Opens up a whole new world in metalwork for 100 bananas
            edit: a decent bench vice helps, plus a wire brush/chipper, I also use a drill wire brush
            edit 2 (lol) plus an angle grinder
            Edited By Ady1 on 05/08/2018 00:03:53
            #365630
            Ray Lyons
              @raylyons29267
              I bought one of these last time they were in stock. Bought one of those metal filing boxes for storage which holds everything except the shield. Used it this week, still working fine.
              A few weeks after I bought mine, Aldi brought out a similar welder but with a digital output indicator.
              #365962
              Clive Foster
                @clivefoster55965
                This Sundays LiDL offers included long gooseneck style LED desk lights. Picked up the last two from local LiDL today intending to use them as machine lights. Gooseneck is 2 ft / 600 mm long overall including the end fixings so flexi bit is a touch shorter. Nice compact light head and decently stiff gooseneck so should work well.
                3 Watt, 120° flood type GU 10 LED in the box. Only 3000°K, warm white, rather than the harsher 6000°K, daylight, variety which would give a more suitable light.
                But for a penny under a tenner who's complaining.
                Worst point is the tight fit and excessive recessing of the LED bulb in the metal cover. Snazzy little suction cup provided to fit the bulb. Which does work but cup is transparent plastic. Mean time to loss probably best measured in seconds. TMT (Too Much Technology).
                Clive.
                Edited By Clive Foster on 06/08/2018 20:07:19
                #367618
                Russell Eberhardt
                  @russelleberhardt48058
                  Just bought a "Rapporter d'angle numérique" (digital angle gauge) for €9.99, complete with branded lithium cell. Checked it against my Moore and Wright set square and it reads 90.0° so can't be too bad.
                  Russell
                  #367667
                  V8Eng
                    @v8eng
                    Posted by mechman48 on 04/08/2018 12:35:08:
                    Keep looking in at my local Lidl for one of those small inverter welders, just missed out last time they were in. Any one get one, did they have tongs / earth clamp?. I suspect they would have to be bought separately so adding cost, plus welding shield / helmet, another £40+ if its a auto darkening shield.
                    George.
                    I picked up a Lidl leaflet on my way home from the dentist yesterday which shows for Sunday 19th an inverter (stick) welder for £59.99 and automatic helmet at £24.99.
                    #367671
                    Ady1
                      @ady1
                      Dropping into Aldi is also recommended if you are passing by one
                      They can sometimes be better than Lidl, more gear on display for longer
                      #367676
                      Carl Wilson 4
                        @carlwilson4
                        V8eng my local Lidl still has inverter welders. If you want I can get one and post it to you. Reimburse me for the cost and the postage.
                        Carl.
                        #367677
                        V8Eng
                          @v8eng
                          Carl. Thanks for the very kind offer but my post really was intended for mechman48 regarding a listing in the new Lidl leaflet.
                          I had noticed these units at Lidl a few weeks ago, unfortunately my stick welding skills are literally more stick than weld, I am more familiar with Oxy Acetylene for welding and copper brazing.
                          Thanks. V8.
                          Edited By V8Eng on 16/08/2018 17:22:14
                          #367689
                          Nick Hulme
                            @nickhulme30114
                            My local Lidl had 3v Lithium cell powered digital calipers this week, same model I've been using without issues or Lithium cell replacement, some for 2 years and others for 4 years.
                            #368087
                            Howard Lewis
                              @howardlewis46836
                              Today, they had Digital Callipers, £9.99 and adjustable clamps, as well as Diamond Files (round or conical) at £1.99.
                              Telescopic ladders (3.43Metres) at £79.99 if you want to go up in the world!
                              #368176
                              mechman48
                                @mechman48
                                …been on Lidl's website past couple of days… 'non food offers for Sun.19th'… doesn't mention a word about inverter welders, admittedly haven't been & looked in my local store so…?, if I see one I'll be sorely tempted to ignore the finance director's comments about Cap.Ex … face 22.
                                George.
                                #368192
                                Stuart Smith 5
                                  @stuartsmith5
                                  George
                                  I bought a welder and helmet from my local lidl yesterday. Haven't had chance to try them yet but look ok especially at the price. The shop opened at 10am and when I went in at 10.15 they only had 2 welders in stock , but quite a few helmets.
                                  Stuart
                                  #368193
                                  mechman48
                                    @mechman48
                                    Thanks for the update Stuart; will call in local tomorrow… if there's any left … ? would appreciate you letting me know how you get on trying it.
                                    Stuart.
                                    #368212
                                    Les Jones 1
                                      @lesjones1
                                      From yesterday (18t August.) they had lithium ion batteries and chargers. Thy call them 20 volt but they are the same as what is normally called 18 volt. I bought some of the 2 amp hour ones a few months ago when they were last on offer to use with an 18 volt drill whose nicad batteries had failed. I had to make an adapter from one of the old battery cases to fit the connector on these batteries. They work well with this drill.
                                      Les.
                                      #368215
                                      Phil Whitley
                                        @philwhitley94135
                                        very good point Les, I walked past them today, and I have an 18v drill with a knackered battery, will pop in tomorrow and get one!
                                        #368322
                                        mechman48
                                          @mechman48
                                          Called in to local Lidl's, no welders or helmets. Still had a few lithium ion drills, batteries, clamps etc. Seems like I missed out, again, if they ever had them in ?
                                          George.
                                          #368409
                                          Ady1
                                            @ady1
                                            If you drop by the following week there have sometimes been units passed on from adjoining shops who didn't manage to shift their stock
                                            Units get shuffled to outlets where demand is greater
                                            Edit: Aldi do stuff online as well as instore now
                                            Edited By Ady1 on 22/08/2018 09:16:48
                                            #368457
                                            Punctured Bicycle
                                              @puncturedbicycle
                                              I picked up one of the 20V 4A batteries for my cordless angle grinder I got a few weeks ago. Haven't tried it in anger yet, but hopefully it will give it a bit more oomph and/or runtime. Very pleased with the grinder. Variable speed and much quieter than my mains-powered grinders.
                                              I also got one of the cordless multi-tools. This seems pretty nice and has a tool-free blade change feature which is handy.
                                              @mechman48 I don't know what part of the country you are in, but they had plenty of welders and helmets in the two Bristol Lidls I visited. This surprised me as those items aren't listed on the website as current offers.
                                              Edited By Punctured Bicycle on 22/08/2018 16:00:37
                                              #373594
                                              Ady1
                                                @ady1
                                                The cordless impact wrenches are back !
                                                If you can find one
                                                Can also plug into the 12v lighter socket, very handy for roadside work
                                                1/2 inch nose, 300Nm loosening torque
                                                3 year guarantee, 40 bananas
                                                #373604
                                                Mick B1
                                                  @mickb1
                                                  The Parkside cordless Air Pump and Compressor are going at £24.99 in a new branch near us:-
                                                  …and I've found both useful already.
                                                  #452470
                                                  Ady1
                                                    @ady1
                                                    Got the cordless compressor and air blower, 40 bananas this week
                                                    up to 100psi with a digital pressure limit switch
                                                    Nicely made bit of kit, one of those "when you need it " things
                                                    edit: they also had welding masks in, ~23 bananas
                                                    Edited By Ady1 on 16/02/2020 09:44:05
                                                    #528463
                                                    Ady1
                                                      @ady1
                                                      Brushless drills are about again
                                                      Got a huge boxful for 100 bananas, the alminium toolbox alone would be 30 quid
                                                      5 year guarantee
                                                      Over 200 from other brands, a really decent brushless unit
                                                      Only downside is it's pretty solid and weighty because its so tuff, but they're great for drilling metal
                                                      Edited By Ady1 on 19/02/2021 11:04:28
