The trouble with Neil’s square is that if the column is out in both directions, and you put a dti at say the back is any indicated dial movement a result of a tilt in the y direction or is it caused by the indicator rolling round the pillar(edit) in the x direction.
But if you go for the double square as indicated by Chris then you will eliminate this problem.
However, if the machine trams correctly then it will produce accurate work unless you are without a quill for adding cut, however the change to the geometry of any cut would probably be less than the deflection of the tool under load..
What type of machine is it? if it trams how does the problem affect your workpiece?
You need to give more information in a request such as this
Borrowing expensive precision kit as suggested earlier is not that easy for most mortals.
Edited By Zan on 01/12/2018 19:28:25
