I have soldered a couple of pieces mild steel together, and they ended up with a small twist. About 1mm over 120mm.
It is the frame of Myfordboy's powered hacksaw.
I think this twist will result in the blade trying to move sideways about 0.5mm during the cut.
I would like to re-work it for my piece of mind.
My question is: Do I need to break the joint and clean back to base metal, or can I simply clean the surface, re-flux and re-heat – maybe adding more solder if required.
I am using easy-flo/silver-flo55.
Thanks.
