Posted by William Harvey 1 on 11/12/2021 13:44:50:
Ah just sussed it, I looked in my small box of taps and found another 3/8 NC 16 tap (left in the pic). This one is much smaller, the other one that starts STI Helicoil Set?
You're right – the larger tap cuts a thread to take a wire insert core, and the insert takes a 3/8"-16 screw. STI = Screw Thread Insert. It's "special".
Unless you're in North America best not to get entangled with US threads unless you have to, especially inserts. The mixture of Imperial and Metric Threads available in the UK is quite confusing enough.
Have you picked up a bargain box of unknown tools? They often contain surprises – stuff bought to do special repairs etc. They may not match your needs, for example I associate inserts with repair work rather than Model Engineering.
To keep my non-modelling experimental workshop simple, I majored on metric threads and only buy in BA, Whitworth and UN as required – not often! A modeller might tool up with BA, BS and ME threads for the same reason, and only use metric on special occasions.
Do you have a particular hobby direction in mind? (I didn't at first.) If so, might be better build something to a local plan, and buy whatever is needed to do it.
Edited By SillyOldDuffer on 11/12/2021 15:18:20
