Barlows Formula for the burst pressure in psi of a pipe is:
P = (2 x wallThickness x tensileStrength) / outsideDiameter
The tensile strength of copper varies between 36000psi and 47000psi. Unless you know better use the lower value!
For 3/16" pipe applying the formula gives:
Thickness |
SWG |
Inches |
Burst psi |
16 |
0.064 |
24576 |
18 |
0.048 |
18432 |
20 |
0.036 |
13824 |
22 |
0.028 |
10752 |
26 |
0.018 |
6912 |
As a check the calculated burst pressure of an ordinary copper water pipe would be about 2400psi. This, I think, agrees fairly well with Phil's link to Table Z which gives a working pressure for that sized pipe of 725psi. ie for a cold water pipe, the safety factor is about x3⅓
With a steam pipe you wouldn't want to get anywhere near burst pressure especially as the higher temperature will reduce the metal's tensile strength slightly. I'd apply a safety factor of at least x10.
Applying Barlow with safety factors, for 3/16 o/d 26swg copper pipe an x10 safety factor is 691psi and x20 is 345psi. On that basis I'd say 26swg 3/16" pipe is plenty good enough for a 100psi boiler and any reasonable hydraulic test.
Although the theory looks reasonable to me prefer the opinion of any boiler expert or mathematician who happens to disagree!
Edited By SillyOldDuffer on 12/01/2019 16:20:33
