Copper Tube.
Copper Tube.
Home Forums Materials Copper Tube.
  • #30086
    Bo’sun
      @bosun58570
      Getting it straight?
      Bo’sun
        @bosun58570
        Good morning,
        I've just bought some 4mm O/D copper tube, and as expected, it came in a coil. Albeit a little tighter than I would have liked.
        Are there any tips for straightening it out, other than patience? I don't expect to get it arrow straight by any means, but somewhat better than it is would be nice.
        #512346
        Former Member
          @formermember12892
          #512347
            Rolling between a flat surface and a board about 4" wide in your hand works fairly well. Remember and straightening will start to work harden the copper so best to anneal before you start to bend it.
            #512348
            Bo’sun
              @bosun58570
              Thanks for that, annealing will have to done a section at a time. The final aim is to produce a close fitting cooling coil, so the piece needs to be reasonably long to start with.
              #512354
              PaulG
                @paulg46657
                Don't know about this size but there are small hand tools to do this by pulling through rollers. Sold by brake pipe suppliers but I may have seen them elsewhere – "Repair Shop" perhaps.
                #512371
                ega
                  @ega
                  Tubal Cain dealt with this in WPS28.
                  #512378
                  not done it yet
                    @notdoneityet
                    Posted by Bo'sun on 08/12/2020 11:37:41:
                    Are you annealing it with a fag lighter?🙂 Getting it straight, by rolling between flat surfaces, might have limits to length, but any decent gas torch should enable you to steadily progress from one end to the other.
                    #512383
                    Emgee
                      @emgee
                      Posted by PaulG on 08/12/2020 11:43:27:
                      This works on MICC (mineral insulated copper covered) cables.
                      Emgee
                      #512384
                      Former Member
                        @formermember12892
                        #512391
                        Bo’sun
                          @bosun58570
                          So that I can wind a close/tight fitting coil around a cylinder giving good conduct.
                          #512402
                          Bo’sun
                            @bosun58570
                            I'm hoping that annealing will reduce "spring back", further helping me to get a close fit. I have considered using a heat conducting compound if need be. Any comments on using such a material appreciated.
                            Just in case you're wondering. I'm experimenting with a water cooling coil around the "cool" end of a Stirling Engine transfer cylinder.
                            #512405
                            Bo’sun
                              @bosun58570
                              Posted by ega on 08/12/2020 12:42:33:
                              Hi ega, do you have a link? That reference doesn't yield anything.
                              #512417
                              Jeff Dayman
                                @jeffdayman43397
                                Hi Bo'sun, by using a pipe applied to the hot end, you introduce a barrier to heat conduction at the interface of the pipe to the hot end part. Every such barrier will seriously reduce heat transfer from a hot item to a cooler item. If you can fit a water jacket around the hot end and transfer heat directly from the hot end to the cooling media the heat transfer will be far better. This method is used in the majority of liquid cooled IC engines in the world, for good reason. Only mentioning it as food for thought, and may save some cost and time straightening copper pipe.
                                #512420
                                  Jeff, not sure why anyone would want to put a cooling jacket or coils around the hot end of a stirling engine as you heat the hot end and it's the temp differential between hot and cold ends that makes them run so heat the hot end and cool the cold end either with fins for air cooling or jacket coils for water cooling.
                                  Materials are also selected to reduce heat transfer not encourage it
                                  Edited By JasonB on 08/12/2020 16:18:58
                                  #512424
                                  Bo’sun
                                    @bosun58570
                                    I'm no expert, but I wondered the same.
                                    #512474
                                    old mart
                                      @oldmart
                                      Posted by Bo'sun on 08/12/2020 15:15:43:
                                      COOL,not Hot end, he said.
                                      #512480
                                      duncan webster 1
                                        @duncanwebster1
                                        … I have considered using a heat conducting compound if need be. Any comments on using such a material appreciated.
                                        Devcon used to be the stuff, the one loaded with aluminium -powder. Soft solder would be better I think. However as others have said a proper water jacket would be a lot better. If you're pumping the water then arrange the flow to be tangential in at one end and tangential out at the other, then it sort of spirals round and you don't get any dead spots
                                        Edited By duncan webster on 08/12/2020 21:35:15
                                        Edited By duncan webster on 08/12/2020 21:35:52
                                        #512501
                                        John Baron
                                          @johnbaron31275
                                          Hi Guys,
                                          In the old days before I retired, I used to straighten 50 foot lengths of 6 mm copper tube for making coils by stretching the tube. It was anchored at one end to a steel peg and stretched by pulling it with a four foot lever at the other. The very slight reduction in diameter didn't matter at 144 Mhz.
                                          #512507
                                          Tim Stevens
                                            @timstevens64731
                                            Another way to straighten tube (or wire, etc) is to unwind as much as you can, fit one end in the vice, and pull the other. As you do this you will feel the metal 'give' as you get past the springiness. That should be enough – at the cost, of course, of 2cm at each end.
                                            If you don't feel the 'give' it may be that the tensile strength is more than you can pull. Annealing will help – but this can be counter-productive if you need elasticity – eg when making a coil spring.
                                            Oh, look, John Baron has just beaten me to it.
                                            And you will improve conductivity between tube and cylinder with solder – soft or (even better) hard.
                                            Cheers, Tim
                                            #512519
                                            ega
                                              @ega
                                              Posted by Bo'sun on 08/12/2020 15:27:13:
                                              WPS28 = Workshop Practice Series no 28 which is entitled Simple Workshop Devices.
                                              You may feel you already have enough advice but I could send further information if you PM your email.
                                              The book is one of the better in the series.
                                              #512531
                                              Jeff Dayman
                                                @jeffdayman43397
                                                Sorry re my brain fade / typo hot end vs cold end, of course OP did mention cold end was where he was working. I still think a water jacket where you want to transfer heat will be much more efficient than coils wound around. I agree with others who suggested soldering the coils or using heat transfer compounds would help if coil must be used, but a jacket and liquid or gaseous cooling media is a better method to move heat.
                                                #512532
                                                not done it yet
                                                  @notdoneityet
                                                  Just as a suggestion….
                                                  One can buy flat copper tube for radiators, etc. Don’t know whether it could be bent in a tight curve without collapsing or how to do it if it could (maybe fill it with Wood’s metal or something equivalent/suitable?).
                                                  #512534
                                                  Bo’sun
                                                    @bosun58570
                                                    Thanks Jeff,
                                                    Yes, a water jacket would be a better idea, but for expediency and simplicity, and after all it is an experiment, I'll give the water coils a try and see how we go.
                                                    #512556
                                                      An experimental idea could be using a CPU cooler with a water pump or heat pipes.
                                                    Home Forums Materials Topics
