Copper rivets
Copper rivets
Home Forums Materials Copper rivets
Viewing 15 posts - 1 through 15 (of 15 total)
  • #278409
    Chris Hammond
      @chrishammond37041
      Hi all
      Can anyone help me with a UK supplier of 1/32 copper rivets, plus 3/64 copper and steel rivets please?
      I've done a google search and found brass rivets at 1/32 but not copper.
      Many thanks in advance.
      Chris
      Edited By Chris Hammond on 17/01/2017 14:58:27
      Chris Hammond
        @chrishammond37041
        #278414
        norman valentine
          @normanvalentine78682
          GLR Kennions have the 3/64ths in copper and steel. For the 1/32nd rivets couldn't you just get some 1/32 copper wire and form your own heads?
          #278417
          Lambton
            @lambton
            Chris,
            Try EKP Supplies Tel. 01598 710892
            http://www.ekpsupplies.com
            #278421
            KWIL
              @kwil
              1/32" – 2" dia
                I have seen 1.0mm copper rivits from one of the german ME suppliers which is between 3/64 and 1/32
                #278423
                Chris Hammond
                  @chrishammond37041
                  Thanks guys. They aren't for me, but for a buddy in the States.
                  #278436
                  Emgee
                    @emgee
                    Posted by KWIL on 17/01/2017 15:21:00:
                    1/32" – 2" dia
                    Good link from KWIL
                    I'm amazed by the number and types of rivets supplied by this Birmingham based company, if they don't list a suitable rivet for your job I would be surprised.
                    Emgee
                    #278438
                    MW
                      @mw27036
                      It's important to note the difference between copper rivets, which is simply a solid piece of copper that has to be hammered into position.
                      Whereas the self collapsing copper/aluminium rivets have a parent material main body and a steel mandrel, they wouldn't be able to function unless it had the strength of the steel to "draw upon" (pun intended).
                      Michael W
                      Edited By Michael-w on 17/01/2017 16:26:22
                      #278466
                      Chris Hammond
                        @chrishammond37041
                        Thanks all for taking the time to reply. Much appreciated.
                        #278519
                        D.A.Godley
                          @d-a-godley
                          Chris
                          I would recommend Sapphire Products , from whom I bought some just a few days ago , ordered Thursday , delivered Friday , their service is superb . I have no connection other than satisfied customer .
                          #278520
                          Chris Hammond
                            @chrishammond37041
                            Thanks D.A.G. – I'll check them out.
                            #278533
                            Jeff Chilver
                              @jeffchilver13861
                              Useful tip for "decorative " rivets i.e. tender sides running boards and similar locations where the rivet is not required to actually hold something .
                              Take a length of copper wire from scrap electrical twin and earth cable ( easy to scrounge offcuts ) I mostly use the earth conductor as you don't have to strip the insulation , anneal said bit of wire , drill a hole a neat fit for said wire . Cut a clean end on the wire using electrical snips without leaving an upstanding " V " on the end . It is most important that the end is flat . Lay job on a steel block and push the wire into the hole until it contacts the block . Drop a washer down the wire until it lays on the job ( you will need to experiment on a bit of scrap to get correct thickness of the washer Start with about 40 thou for a dummy 1/16 th size .) Using the snips with their flat face against the washer cut the wire flush with the washer . remove the washer and use a rivet snap to form a head on the protruding bit of copper . Takes one tap with a hammer . This dummy rivet wont fall out and neither will it leak if it is in an unpressurised tank . DO NOT do this if there is pressure involved also not suitable for holding components together .
                              Took a lot longer to write than it does to do it . P.S save the Washer( s) and bits of left over wire for future use .
                              Jeff.
                              #278571
                              Chris Hammond
                                @chrishammond37041
                                Thanks Jeff, great post. Will pass the advice on to my buddy.
                                #278701
                                Jeff Chilver
                                  @jeffchilver13861
                                  Chris pleased to be of help ,
                                  Jeff
                                Home Forums Materials Topics
