Back, just replied to another post about a Minnie boiler, the throat plate to boiler joint doesn't have a flange, just a simple 1.5mm thick solder joint. In MY, emphasise MY, book that is simply unacceptable.
Duncan's comment about getting hung up on the 5 thou gap is simply wrong. I am an electronics engineer, and have had to cope with surface mount components, and a 5 thou gap simply means the item fails later on. Tin solder is awful stuff, I have to hand solder, fine if you have got the gear to flow solder the 98% tin 2% silver solder. But even that fails after a few years. I have been seriously burnt by lead free solder, I won't use it.
There is lots of comment about expansion, yes, but why is a solid tube plate different to a flanged one? The solder is easily able to cope with the stresses created, as is the copper sheet, not a problem. It all comes back to not really knowing just how much solder is in the joint. There will also be a slight reduction in water space, but just shift the plate to keep the 1/4" or whatever gap between plates, firebox isn't going to notice.
I will buy a little boiler and make it.
As said there have been thousands of boilers made, but where are they? Going back to the 40's and models were made everywhere, but do you see them? The exhibitions all seem to have new models. Beginnings to wonder if all the thousands have actually been turned into static models, or simply scrapped. Seems like making boilers from steel, up to 2" scale, just having to scrap the thing after 100 steamings because you have no idea of its condition.
Boiler bangs are not a problem, keep it that way!
