Copper boiler descaling
Home Forums Help and Assistance! (Offered or Wanted) Copper boiler descaling
  • #727856
    Zan
      @zan
      At the end of last years season the pump uo my 3” waggon packed up.  This was traced to a slipped sleeve fitted to reduce the delivery  a repair was made.  Today, I was doing a pre season test steam and found the hand pump needed a high degree of force to make it work
      on investigating things, eventually the feed clack was removed, and I was alarmed to see that the delivery hole was only about 1mm dia.  It was clogged with scale.  On removal, hard scale had to be “drilled” out to the 3/16” that it should be    So that’s why the pump appeared to fail – nowhere for the water to go!
      obviously the rest of the boiler  must be heavily scaled   I see Hcl , brick cleaner, citric acid and kilrock (from B&Q) mentioned in some posts in the past for a quick and effective cure
      What have members used ? And what dilution rates, timing etc should I aim for?.
      Paul Lousick
        @paullousick59116
        We use vinegar to clean the injectors on our steam engine. Use the cheap type sold at your supermarket which is used for cleaning. Soak parts in 100% vinegar. It is only a mild acid.
        #727887
        duncan webster 1
          @duncanwebster1
          Kettle descale has been recommended before, no idea what its chemistry is
          Edit: Google suggests copper is attacked slowly by hydrochloric acid, the oxide film dissolves, but is continually replenished by the oxygen dissolved in the water used to dilute the acid. I think brick acid is hydrochloric.
          #727901
          DC31k
            @dc31k
            Every proprietary formulation you buy (e.g. Kilrock) will either have its chemical content written on the label or it will be available from the manufacturer’s website on the MSDS (material safety data sheet).
            Every proprietary formulation you buy will be a basic industrial chemical with 300% markup on the price for packaging and marketing,
            Specific boiler descalers are available:
            https://www.heritagesteamsupplies.co.uk/boiler-maintenance/boiler-descaling/dynamic-descaler.html
            https://feedwater.co.uk/product/acid-cleaner-descaler-bundle/
            #727902
            duncan webster 1
              @duncanwebster1
              Both of those products contain hydrochloric acid
              #727938
              Zan
                @zan
                Thanks dc3 but they cost a bundle and I bet there’s a load of carriage as well.  . I’ll try b&q first!
                if that doesn’t work I’ll try the brick cleaner. The scale deposit is thick when observed through the clack bush
                #727968
                DC31k
                  @dc31k
                  On Zan Said:
                  …they cost a bundle…
                  You are missing the point in two ways.
                  First, download the instructions and MSDS for the commercial items. They do not cost money. They will tell you a lot about what is in the liquid and how to use it (duration of application, temperature, circulation and neutralisation requirements). That information will be of use to you when you come to use whatever witch’s brew you eventually choose.
                  Second, compare the cost of a known, commercial item that would not be sold if it did not work with the cost of replacing your boiler if you ruin it with a home made concoction pulled from the shelves of a DIY store (Kilrock 400ml £13.15 per litre B&Q; Heritage Steam £15.12 per litre assuming it is in the 10kg delivery band). As Duncan points out, both the copper-safe commercial products are hydrochloric acid-based (sulphamic acid is one of the alternative options). Specifically, they are not sulphuric, acetic or citric-based so that can guide your choice of an alternative product.
                  #727980
                  Harry Wilkes
                    @harrywilkes58467
                    Kettle descaler as suggested is what I use
                    H
