Posted by Robert Atkinson 2 on 16/08/2020 17:42:20:
… I think the most likely cause of the failures is negative spikes but unless an oscilloscope is put on the car we are just making assumptions, some based on experience, some guessing.
I concur! It can only be a guess, but negative spikes fit the bill.
Summarising the evidence:
- 92 year old car, 12v electrics from a dynamo but the regulator is modern.
- Lighting system is LED throughout.
- LEDs appear to be automotive types apart from the failing 3mm type which is an ordinary panel LED with built in dropper resistor.
- Failing LED is switched on & off with the sidelights and glovebox.
- LED fails when the engine is running, works OK off the battery. Other LEDs on the same circuit are reliable.
- Failing LED is in the door with the oil-pressure gauge? Presumably the gauge and LED wiring run in parallel for some distance, and the gauge wires connect to a sensor on the engine near the ignition. Possibility of inductive or capacitive pick up
- Flasher indicator LED flickers at low rpm despite being off. Suggests inductive or capacitive pick up of ignition pulses.
- Maurice's test shows LEDs aren't overly sensitive to positive spikes; his similar 12V 3mm example survived 32V.
Provided the current doesn't last long enough to overheat it, LEDs can be deliberately pulsed to increase peak power output substantially, perhaps to increase the range of a TV remote. I think LEDs are relatively immune to positive spikes. The same can't be said about negatives! Although failure at -4V or -5V is typical, some LEDs avalanche at -1V, while others can stick -15V. Not sure what happens if the negative current is limited by a resistor; but I suspect LEDs are much more vulnerable to negative spikes than positive. Perhaps an experiment is in order!
Car electronics are beefed up to cope with grubby automotive power supplies. I think Tim's working automotive LEDs are protected against spikes, while his 3mm indicator LED has no built in protection. As Robert's Zener circuit protects against positive and negative spikes, there's a good chance it will do the necessary.
Love to put an oscilloscope on Tim's car. I guess the trace with the engine running would show an average 13.8 vdc regularly modulated by short positive and negative going spikes at ignition frequency, which is what Tim suspected at the outset. But without an oscilloscope or peak voltage detector it's guesswork.
