Convince me I don’t want a Warco surface grinder
Home Forums Workshop Tools and Tooling Convince me I don’t want a Warco surface grinder
  • #645244
    jaCK Hobson
      @jackhobson50760
      I wish I had one of those small Warco surface grinders. They now cost over £3000. Usually they are out of stock so are not a real temptation but now Warco says 'almost sold out'.
      Why do I want one:
      Small morse taper fittings for a cowells. Make 8mm collets. (I have made some without a grinder)
      Make thin taper ground sheet for small handsaws. (I don't think taper ground makes much difference in reality)
      Sharpen end mills.
      Make parts for folding knives. (I have made some without a grinder)
      It might fit in the spare space in my workshop.
      I get to learn about surface grinding (this probably the only real reason).
      Why Warco
      New – so should work out the box. I imagine a knackerd grinder is more frustrating than a knackered lather.
      Small – it fits.
      Easy delivery – I don't like hassle.
      There is no competition.
      You never seem them second hand. I guess they might have quite good resale value (in terms of %, not total amount lost).
      jaCK Hobson
        @jackhobson50760
        #645247
        John Hinkley
          @johnhinkley26699
          I recently had my Warco grinder up for sale on this site but the two replies I got came to nothing so I decided to keep it. I could be persuaded to part with it if you can arrange pick up. It is as new and I don't want to make money from it, so it's competitively priced (you'll be surprised). You have no profile so I don't know where you are. I'm near Doncaster, South Yorkshire. PM me if you could be interested.
          P.S. I need to downsize my workshop while I'm still above ground and breathing.
          #645294
          duncan webster 1
            @duncanwebster1
            I'm not sure how you make morse hitapers on a surface grinder.
            #645299
            Pete Rimmer
              @peterimmer30576
              Posted by duncan webster on 16/05/2023 00:21:05:
              If your machine has the cross-travel you could make some sine centres and drive one end with a dog.
              #645306
              jaCK Hobson
                @jackhobson50760
                #645307
                HOWARDT
                  @howardt
                  Do you need one for surface finish or sizing. If sizing then have you the measuring kit to accurately measure size and angles.
                  #645308
                  mgnbuk
                    @mgnbuk
                    How fit are you ?
                    Manual surface grinders are a good workout, particularly on larger parts.
                    Nigel B.
                    #645310
                    jaCK Hobson
                      @jackhobson50760
                      I don't 'need' one. It's a hobby… just playing.
                      #645323
                      not done it yet
                        @notdoneityet
                        Posted by jaCK Hobson on 16/05/2023 08:35:16:
                        Agreed. I don’t often use mine – but when needed, it is there.🙂 I now don’t have to bother about the finish on some parts from the mill – particularly fly cutting – if it can be sorted on the surface grinder. Extra time, but it is only a hobby.
                        Edited By not done it yet on 16/05/2023 09:16:09
