Converting fractions to decimals
Home Forums Hints And Tips for model engineers Converting fractions to decimals
Viewing 19 posts - 76 through 94 (of 94 total)
  • #558888
      Posted by Howard Lewis on 18/08/2021 23:11:09:
      This looks be getting a little bitter and twisted, when we are taking of UNITS.
      Thank you for trying to inject the Wisdom of Solomon, Howard … but the thread is [or at least was] really about converting between factions fractions and decimals.
      Edit: __ corrected my Freudian slip of a typo blush
      Edited By Michael Gilligan on 19/08/2021 06:45:44
      Circlip
        @circlip
        "Or log tables if you're some kind of luddite/weirdo/masochist."
        I resemble that remark and only work to the "rough" sizes using four figure logs and not super accurate six figure versions, but I can convert ingrish to meterick without having to use t'nternet or Collosus and can still work to a "Proud" sixteenth or a "Shy" thirtysecond and it might not to be to NASA standards of accuracy but it works.
        Regards, Wot tiller.
        Edited By Circlip on 19/08/2021 09:05:08
        #558904
          Posted by Michael Gilligan on 19/08/2021 06:21:30:
          Ah, but the subject has hidden depths. The discussion leads to the need for change, which is mankind's greatest enemy. Hard to teach old dogs new tricks because old dogs see no reason to change. This is why I'm handling my mother's hospitalisation by landline telephone while the rest of the family are in a WhatsApp group. I ring family to tell them the latest news and everyone in the group is already better informed than me. I resent it slightly, because they've been using new technology for years while I still hanker after dials, telephone directories and pressing Button B to get my 4d back in a red box smelling of wee.
          Very upsetting – I have trusty old friends like Landline telephony, Imperial Measure and Fractions, and some young whipper-snapper barely out of nappies points out they're all actually a bit sh1t, giving reasons I don't understand or give two hoots about.
          Our hobby sits on a fault line; is Model Engineering about retro-technology like steam engines, Whitworth and HSS on a 1947 lathe, or is it about Quadcopters, microcontrollers, CAD, laser-cutters and 3D-printing? I think it should be about both. I admire craftsmanship and enjoy my manual lathe and milling machine, but I'm also interested in state of the art methods and what's in the pipeline.
          The history of engineering shows new techniques always win and it's a bad mistake to cling to the past. Discuss!
          devil
          Kiwi Bloke
            @kiwibloke62605
            OK Dave, I'll bite!
            Good, provocative thoughts. I thought the subject deserved its own thread, so I've started one, in the Tea Room.
            #558922
            Tim Stevens
              @timstevens64731
              Silly old duffer says:
              I remind you all that without change (enemy or not) we would still be living in the sea along with lots of identical precambrian jellies.
              Further – I had not anticipated the nooks and crannies into which the discussion would flow. I will try to think of something else as inspiring, in case this thread runs out.
              Regards, Tim
              #560473
                This Moore & Wright booklet includes an extensive and very clearly tabulated set of conversion tables: **LINK**
                https://ia802901.us.archive.org/26/items/moore-and-wright-micrometers/Moore%20and%20Wright%20Micrometers.pdf
                Howard Lewis
                  @howardlewis46836
                  Been watching this with some amusement.
                  Am a fully paid up Luddite (aka Ancient Oddity or Dinosaur – although they went extinct a long time ago! )
                  The older Mill/Drill is Imperial to match nearly all my measuring kit. The lathe is Metric but dual dialled, so MOSTLY, I work in Imperial. (Using a digital Calliper most of the time with a mechanical instrument for a second opinion )
                  The drawings / sketches and calculations are mostly on the back of an envelope, often thinking in Fractions, which appear as decimal inches on the envelope!
                  Was taught Log tables at school, and the virtues of mental approximation, but starting work had to learn how to use a slide rule (Had never fathomed father's Japanese Bamboo one! )
                  Was told at Tech that it was basically, log tables plotted out in linear form. THEN the penny dropped, and was amazed at the accuracy with which results could be interpolated.
                  Too ignorant to really write my own programs, but do use EXCEL for spreadsheets.
                  The one that I wrote (? concocted ) to correct my HV6 expands from time to time. Just insert a new number of divisions, and it tells you how many turns and holes are needed (CANNOT find a drill to drill decimals of hole though! )
                  Would take up 3D printing, IF I could think of a use for the things that I make / mend / modify.
                  Favourite calculator is solar powered, so has to be used under a light after dark!
                  #564392
                  Nigel Graham 2
                    @nigelgraham2
                    I've a Zeus book and one of those big poster-sized Tracy Tools conversions + tapping-size charts in the workshop; plus another and a calculator indoors next to the computer (for when using CAD).
                    Simpe as that…
                    No need to write and print spreadsheets etc. It's all been done for you!
                    #564539
                    Oily Rag
                      @oilyrag
                      What's this about calculators – I thought modern phones had replaced cameras and calculators in one fell swoop!
                      Martin
                      #564546
                      Calum
                        @calumgalleitch87969
                        Not at all – I have a little app on my phone that reproduces a complete slide rule, with my own choice of scales on it (Infinirule, it's called, for the curious). I even use it every once in a while.
                        #564719
                        Nicholas Farr
                          @nicholasfarr14254
                          Posted by Oily Rag on 27/09/2021 22:27:57:
                          Martin
                          Hi Martin, as both cameras and calculators come in a wide range of levels, I'll doubt that many mobile phones will cover every level there is, but very many of them are very good for entry level. My mobile phone has a very good camera, but it doesn't have the same range or ability of my DSLR cameras and the calculator which is also very useful, doesn't stack up to my scientific ones.
                          Regards Nick.
                          #564739
                          KWIL
                            @kwil
                            #564751
                            John Haine
                              @johnhaine32865
                              Nick, try the Free42 app – an HP42 on your phone. Brilliant.
                              #566244
                              Charles Skeet
                                @charlesskeet99220
                                I don't usually have a problem with this particular subject. 1/2 mm = 0.5 mm, 1/4mm = 0.25 mm, etc. Gotta love the metric system!
                                #566246
                                Circlip
                                  @circlip
                                  I have a napp on my phone that allows me to contact other people and talk to them.
                                  Regards Ian.
                                  #566254
                                  Dave Halford
                                    @davehalford22513
                                    Posted by Circlip on 10/10/2021 10:36:52:
                                    Regards Ian.
                                    I have a napp on a chair, it's more comfortable than a phone smiley
                                    #566329
                                    Dr. MC Black
                                      @dr-mcblack73214
                                      Posted by Tim Stevens on 16/08/2021 11:53:16:
                                      It is a chart of fractional inch sizes (down to 64ths) to millimetres (and four decimal places) for all dimensions from 0 to 12", and then in 32nds to 24".
                                      Sadly the Koken web site does NOT work on my computer!
                                      I put "Koken.co.uk" in the usual place and the Firefox screen remained blank!
                                      I never got as far as the catalogue – pity because the Chart seemed useful (from what was written)
                                      MC
                                      #566335
                                      duncan webster 1
                                        @duncanwebster1
                                        This works on mine koken
                                        #566390
                                        Dr. MC Black
                                          @dr-mcblack73214
                                          I can assure you that the screen remained blank
                                          That may be because my computer was tired so late in the evening but the screen remained blank.
                                          I have now downloaded the catalogue and printed the chart.
                                          I have never heard of "American Inches" in the past.
                                          I think it would be better if printed on A3 paper since the text is VERY small – but I don't have an A3 printer. I'm lucky when my A4 printer works !
                                          With best wishes and thanks
                                          MC
