I’m looking at making a set of mitre gears, 20 tooth 48 DP using the two button method of making the cutter. I have done this for small spur gears before and they have come out satisfactory.
I have Ivan Law’s book and the ME articles by Dave Lammas ( Jul. 91) and D. A . G. Brown (Sep. 94) and looking at the tables for the dimensions of the button diameter, spacing, in feed, and cutter blank width, those of both Lammas and Brown agree very closely but the ones by Law are very different. Only Brown gives the formulas for their derivation.
Out of curiosity I ran through the formulas and found that while the one for button diameter gives values that agree with the table, the ones for button spacing and infeed do not. The values from the formula for spacing give figures consistently higher than in the table. But when plugging the numbers into the one for infeed I get a negative value under the root sign (which is impossible). So either I’m reading the formula wrong or there is a mistake in the formula. Anyone else tried to use these formulas and can shed some light on this??
( The way I read the infeed formula is, Cutter infeed F= 1.25 + sqr root of the quantity “ { (D/2)sqr’d – [ D/2 x cos bravo – T/2 + pi/4]sqr’d} – d/2 x sin bravo ".
