Connecting battery charger fly leads
Home Forums General Questions Connecting battery charger fly leads
Viewing 25 posts - 1 through 25 (of 34 total)
  • #605523
    john halfpenny
      @johnhalfpenny52803
      Modern cars are power hungry when locked, and will often show low battery after a few weeks. For this reason it is prudent to charge the battery occasionally, and for convenience permanent fly leads and a plug, for say a CTEK charger, may be attached. It is always recommended to attach the permanent fly lead earth to the vehicle body rather than the battery terminal. Why is this? I have seen it said that direct connection to the battery terminal can fool the adaptive charging system which modern cars employ – could someone explain this in terms appropriate for a mechanical rather than an electrical engineer.
      john halfpenny
        @johnhalfpenny52803
        #605524
        not done it yet
          @notdoneityet
          Very simple. Any spark that might be generated at connection is well away from the battery – avoiding any risk of battery explosion at connection time.
          #605526
          john halfpenny
            @johnhalfpenny52803
            Yes, I know about explosion risk, but a permanent fly lead could just as easily be connected to the battery post.
            #605527
            bernard towers
              @bernardtowers37738
              another one of those myths that people accept as fact after a period of time.
              #605528
              Maurice Taylor
                @mauricetaylor82093
                Hi ndiy,where do you connect charger earth lead when battery is on floor in shed ?
                For last 50 years I’ve connected leads across battery with no problems.
                I assumed connecting charger to chassis was due to electronics in modern cars
                Maurice
                #605530
                Dave Halford
                  @davehalford22513
                  In some cases the battery is under one of the front seats so using the remote terminals under the bonnet would make sense. Stop start batteries use the more complicated charging system, but no one I can find says you can't connect direct, but you do need an Auto battery charger, so the old Winfield charger needs to be binned
                  #605531
                  Anonymous
                    Many car batteries these days are sealed, so they shouldn't vent hydrogen unless grossly overcharged. So no risk of explosion. I always connect my charger across the battery terminals.
                    #605533
                    old mart
                      @oldmart
                      I use a Motobat smart charger intended for motorcycles, which has only about 1 amp output. They are small and waterproof and I have used it for years to keep the bikes battery in working order by once a month connecting for 48 hours. It was also useful for the car when I was unable to drive after knee joint replacement. The trickle rate is only about 50mA when it senses a charged battery. The charger gets switched on after connecting and off before disconnecting.
                      Edited By old mart on 12/07/2022 21:02:37
                      #605535
                      DMB
                        @dmb
                        I have read all the above posts and note that none mentions this. All connections to the battery or other terminals should be made before switching the charger on. Then there will then be no spark. Explosion is very unlikely as there would need to be a substantial build up of hydrogen and oxygen trapped within a building or shed, garage. That sort of quantity of gases would likely build up after perhaps several hours of charging. However, it would always be best practice not to smoke inside a charging room and avoid sparks, naked flames, just in case…….
                        Edited By DMB on 12/07/2022 21:09:16
                        #605538
                        Mike Crossfield
                          @mikecrossfield92481
                          0n my car (newish Audi, but I imagine it will apply to a lot of modern cars), the current flow in and out if the battery is monitored by a module connected between the battery negative lead and the chassis. This is part of a sophisticated battery management system which includes recharging from regenerative braking. If you connect a charger directly to the battery terminals you bypass the current flow sensor, and allegedly confuse the system. A special chassis terminal is provided for battery charger connection. On my car this is right next to the battery, so no lower explosion risk than a direct connection ti the battery terminal. Incidentally my smart charger can’t be enabled until the leads are connected to the battery, and the power is shut off if the connection is intermittent, so In theory no risk of a spark. I imagine the CTEK is the same.
                          #605539
                          David George 1
                            @davidgeorge1
                            I had an incident when I worked at a motorcycle workshop. I removed a new battery from a Honda 90 which had been sold and put it on charge. There was a large two voltage charger and selected the 6 volt pair and connected and switched it on. Another worker placed a spanner on the same bench which disconnected one of the crocodile clips and caused a spark. I could see a flame travel up the clear plastic tube connected to the battery vent and ran. The battery exploded spraying acid etc over the new bike and other stock. No one was hurt but only just.
                            David
                            #605540
                            john halfpenny
                              @johnhalfpenny52803
                              We are getting off the point of my post. Mention of explosion is a red herring; please assume the PERMANENT fly leads are at least 1 metre long, so the the connection point is well away from the battery. The manufacturers of both vehicles and smart chargers say to use an earth point away from the battery – is it because of adaptive charging, and if so what does the remote earth connection achieve that a direct ( battery post) connection does not.
                              #605544
                              old mart
                                @oldmart
                                When I was a teenager in electroplating, we had a duff plating transformer rectifier which was attached to a 6V lead acid battery. The battery cells were about 1 gallon each, not a tiny car battery. I said to Ray, "try shorting the battery", so he did with a 1/4" diameter nickel plated rod out of the drying oven. As he shorted it, I was leaning over him to get a better look ans a cell exploded. All the acid and bits of the plates and separators and the top of the cell just dissapeared, and neither of us had a scratch. We could have been killed, that cell was about 300AH. We hastly concocted a plausible story and got away with it when the boss appeared seconds later.
                                I have had a healthy respect for batteries ever since.
                                #605545
                                Anonymous
                                  Posted by DMB on 12/07/2022 21:07:19:
                                  …there would need to be a substantial build up of hydrogen…
                                  Not so, hydrogen is explosive in air from 4% to 74%. When I first started working on electric vehicles in the early 90s we were using lead acid batteries. We had to have hydrogen sensors fitted in our battey room and in each vehicle. One of the experimental battery packs we were asked to look at had clearly had an internal fire, suspiciously just above the battery vent.
                                  #605546
                                  john halfpenny
                                    @johnhalfpenny52803
                                    Thankyou Mike – that seems to explain it.
                                    #605549
                                    Anonymous
                                      Posted by Mike Crossfield on 12/07/2022 21:16:39:
                                      That's a new one on me. I've designed the battery management hardware for a number of electric vehicle battery packs, including regen capability. But this was always for the main battery pack, not the SLI battery?
                                      It turns out that regen is not as useful as one might think, not least because the battery needs to be at a relatively low SOC to accept the short term high currents without being over-voltaged.
                                      #605555
                                      not done it yet
                                        @notdoneityet
                                        Posted by Maurice Taylor on 12/07/2022 20:11:23:
                                        Maurice
                                        Yep, I’ve done it safely for 60 years, or so, too. A friend had a battery explode – he was angle grinding the other side of his workshop. The gas from a battery is not just hydrogen. It is water that is electrolysed to hydrogen and oxygen – the perfect proportion for recombining it all back to water.
                                        Charging a battery direct with a decent ctek charger would not really affect any fancy electronics – neither of our cars is like that. I’ve charged literally hundreds of batteries with anything from a trickle charger to a 100A engine starter. 10 starts (or more) on machines, in quick succession was the order of the day at one time. Batteries needed boosting to start the engines, then they were run a while to charge the battery from its generator.
                                        The principle is still the same – that of keeping any sparking well away from the battery.
                                        The sensible ones amongst us do not connect or disconnect the battery charger to the mains until after the leads are connected. Just another KISS principle to follow. The Ctek charger instruction is explicit in this respect. Common sense to those that understand there is a risk – but many are totally oblivious to it.
                                        Even on a ‘modern’ car (both ours are modern but not that new) if the battery needs charging, it needs charging. Full stop.
                                        The adaptive charging will be taken care of when the engine is running. Manufacturers make it difficult for even renewing the battery these days – must go to dealer for them to do it and they make a nice healthy charge for it.
                                        #605556
                                        Oldiron
                                          @oldiron
                                          Posted by Dave Halford on 12/07/2022 20:30:12:
                                          In some cases the battery is under one of the front seats so using the remote terminals under the bonnet would make sense. Stop start batteries use the more complicated charging system, but no one I can find says you can't connect direct, but you do need an Auto battery charger, >>>>> so the old Winfield charger needs to be binned
                                          Dont bin it as it is useful for anodizing/rust removal/testing stuff etc. The new types do not work for those uses.
                                          regards
                                          #605558
                                          Mike Crossfield
                                            According to the technical blurb for my car, the battery management system controls normal charging so that it never charges the battery to more than 80% to leave headroom for regenerative charging. The system does seem to be pretty sophisticated, and, for example, if the battery charge is getting low, or drain is high, it progressively shuts down power consumers so that essential items are kept going as long as possible. It also adapts to allows for battery ageing. One complication is that when the battery is changed the relevant ECU has to be reprogrammed with the details of the new battery or the charging characteristics will be non-optimum. So unless you have the necessary software, a simple battery change turns into an expensive visit to the dealer!
                                            #605559
                                            Mike Crossfield
                                              Double post
                                              Edited By Mike Crossfield on 12/07/2022 22:30:57
                                              #605562
                                              john halfpenny
                                                @johnhalfpenny52803
                                                A modern code reader will reset the car's adaptive charging module to a new battery – no need to visit the dealer. I think in any event a reset will occur over a short time period.
                                                #605564
                                                  I’m not sure if this will inform the discussion in any useful way: **LINK**
                                                  BMW Intelligent Battery Sensor (IBS)
                                                  My BM is too old for such fripperies
                                                  Jon Lawes
                                                    @jonlawes51698
                                                    And I think BMW may hold one of the answers to the original question. My old 5 Series (E39) had a small explosive device on the battery terminal that in the event of a serious accident would sever the battery connection to try to reduce the risk of fire. There were many dire warnings about jump starting and charging in the manual, I think it suggested all these things would be done via the dedicated terminals under the bonnet. The battery was in the rear wing.
                                                    #605572
                                                    Colin Whittaker
                                                      @colinwhittaker20544
                                                      In the large multinational company of field engineers I used to work for we used to have (about once per year) a 12V battery explode when jump starting, sometimes with fatal results.
                                                      Some of the explosions probably came from crossing the leads but others were correctly connected and still exploded presumably because of huge currents circulating between a fully charged battery and a fully discharged battery giving rise to hydrogen gas evolution ignited by a spark from a jumper lead breaking or making a connection.
                                                      The solution, which appeared on stickers in every vehicle, was to ensure that the last jumper lead to be connected and the first lead to be disconnected was to a chassis earth. Thus any sparks were hopefully distant enough from any source of hydrogen to keep things (relatively) safe.
                                                      I believe that in general the advice not to use the battery negative terminal for charging is just to reinforce best practice for the use of jumper leads.
