Connecting a DVD player to a monitor.
Home Forums The Tea Room Connecting a DVD player to a monitor.
  • #271528
    Mark P.
      @markp
      Hello all, here's a question for the electronics buffs. Can I connect a DVD player to a stand alone flat screen monitor so I can watch DVDs instead of using my laptops little screen? I don't have or want to buy a television.
      Regards Mark P.
      Mark P.
        @markp
        #271529
        pgk pgk
          @pgkpgk17461
          I'm no electronics buff.. but i guess it depends on the outputs of the dvd player and the inputs of the monitor you have or intend to get.
          Personally I bought a 46" flat TV some years ago and matched it's RGB input to my PC's RGB output (probably be HDMI now) so I can watch DVD's with the PC's player, watch internet streamed stuff and back in the day actually see the numbers on a many columned spreadsheet.
          Terrestrial reception here is pants so we don't bother or have a licence and the legacy sat dish here isn't connected.
          There's also a  good chance your laptop has appropriate outputs for a monitor
          Edited By pgk pgk on 13/12/2016 11:06:11
          #271535
          John Rudd
            @johnrudd16576
            Posted by Mark P. on 13/12/2016 10:52:39:
            Regards Mark P.
            It all depends on the connectivity of the dvd player and the monitor. There's also the audio side to consider….does the monitor have inbuilt speakers?
            If the dvd and the monitor have composite video and audio sockets then there's no reason why it shouldnt work…
            If you dont already posses these items, then when buying, ask the seller the same question…..'Are these two items compatible to play a dvd? '
            #271547
            Gordon Tarling
              @gordontarling37126
              All modern DVD players will have an HDMI output. There are also very many monitors which have HDMI input(s), so all you need is a single HDMI cable between them and you're sorted for video as well as audio if the speakers are built into the monitor.
              #271553
                Should be possible but depends on what the DVD and Monitor support. There are many possibilities. Are you able to post pictures of the various sockets they have round the back?
                Bazyle
                  @bazyle
                  Can you connect the laptop to the monitor, using the connector that is about 1/3 in high and 3/4 wide and has 3 rows of pins? If so you can divert the laptop screen onto the monitor with a special key combination which on mine is Fn + F3. Which connectors everything has is rather dependent on age.
                  #271560
                  Mark P.
                    @markp
                    Thanks for the replies. Not picked up the monitor or player yet, just checking that I can do what I want to do before I commit myself. Bazyl I really want to create a stand alone system without using the laptop.
                    Mark P.
                    #271584
                    Mike Poole
                      @mikepoole82104
                      Although you say you don't want to buy a TV it will solve you problem at a stroke, you do not need a licence to own a tv but you do if you receive live programmes on it. The connection will be just an HDMI cable and the will take care of everything. A monitor with sound will probably cost much the same as a TV. A new monitor will likely have a VGA port a DisplayPort or DVI or maybe HDMI. There are adaptors for HDMI to DVI but no sound. I think you need to choose a DVD player and shop for a monitor with suitable inputs to match your DVD player if the DVD player has audio outputs you can use a sound system for the audio. Also consider the size of a monitor, a widescreen will be more satisfactory for most DVD material. While I respect your position with the TV it will probably give you the most bangs for your buck and the simplest solution. My wife and I were TV free for about 5 years but persuading the license people we didn't use a TV was an annual event.
                      Also consider a blue ray player, these usually play DVD and audio discs and may future proof you if DVD is superseded by blue ray.
                      Edited By Michael Poole on 13/12/2016 15:25:53
                      #271586
                      Mark P.
                        @markp
                        Mike I may have to bite the bullet and buy a tv, not had one for 15 or so years!
                        Mark P.
                        #271598
                        HOWARDT
                          @howardt
                          I assume you are referring to a DVD player that is normally connected to a TV and not a DVD unit from a PC or Mac. If you use a DVD player and both have a HDMI connector then there shouldn't be a problem ( I think).
                          #271607
                          John Rudd
                            @johnrudd16576
                            A suggestion that counters everything written thus far……
                            Buy a tv with an inbuilt dvd player…..job done, no wires no fuss….just insert and play!
                            Cant get any easier than that…..
                            Edited By John Rudd on 13/12/2016 17:04:57
                            #271611
                            Muzzer
                              @muzzer
                              Have you ever seen one? Even if you have, it must leave a very narrow choice.
                              #271619
                              John Rudd
                                @johnrudd16576
                                Yes I have seen them, I used to work in brown goods……..
                                http://www.currys.co.uk/gbuk/tv-and-home-entertainment/televisions/televisions/logik-l24hed16-24-led-tv-with-built-in-dvd-player-10141132-pdt.html
                                https://finlux.co.uk/tv-22fce274b-nc
                                Why does everything always end up being a pi****** competition when it comes to offering advice and suggestions?
                                There's no need to jump down my throat…..
                                Edited By John Rudd on 13/12/2016 17:47:29
                                #271635
                                  If you want to avoid TV licence issues there are plenty of HDMI monitors for relatively cheap prices. Modern DVD players should all have HDMI out.
                                  Just don't get ripped off for a gold-plated lead.
                                  So teh answer to your question is yes.
                                  Mark P.
                                    @markp
                                    Thank you all for your replies, turns out the monitor I have been given is for connecting a DVD player more inputs than you can shake a stick at!
                                    Mark P.
                                    #272895
                                    Adrian Giles
                                      @adriangiles39248
                                      Both of our bedroom tv's have built in disc players, very handy!
