Condenser/economiser
Home Forums Stationary engines Condenser/economiser
  • #350614
    Jon Lawes
      @jonlawes51698
      I'm currently slowly trundling through my Stuart 10H build and have realised I'll soon have to think about boilers, and all the fun stuff like feed pumps and such. I'd quite like the exhaust from the 10H to feed up the chimney as a primitive blast pipe (Actually more for the look of the thing) so I figure it would be good sense to have a condenser in order to dry the steam a little first. Also it makes sense to pass the exhaust steam pipe through a coil in the bottom of the water feed tank in order to transfer a chunk of heat to the water, helping with the condensing process.
      In my mind (and crude sketches in my lunch hour) I figured I would put the exhaust pipe in a coil in the feed tank which would cool the steam somewhat (And pass a few motes of heat to the water) and then feed that into the condenser. I was just planning a pot-type of condenser that would help to separate any steam oil from the mix. The intention obviously would be to try to minimise any restrictions to the steam exiting the system.
      Can you see any issues with that idea? I did wonder if it would cause water to collect in the pipe but I guess the constant flow of exhaust steam would keep it moving into the condenser/oil separator.
      Thanks chaps,
      Jon.
      Jon Lawes
        @jonlawes51698
        #350707
          Hi Jon,
          Quite a mixture of ideas in your question.
          • Feeding steam up the chimney to look good? Yes.
          • Blast pipe? Probably not, they're used in a locomotive to pull more air through the fire when the engine is loaded. Good for making the engine go faster, bad for fuel economy.
          • Condensers don't dry steam, rather they make it very wet by converting it to water. Condensing water creates a vacuum that's applied to one side of the piston while the other is pushed by steam under pressure, making the engine more powerful and economical. Condensers are controlled by valves in time with the piston. It's part of the engine rather than a simple add-on. Certainly add one for interest, or if modelling an engine that originally had one, but perhaps OTT on a Stuart.
          • As you say a condenser can be configured to separate oil from the steam. This is important when the water is going back into the boiler as in a marine engine, less so when the boiler can easily be refilled with clean water. Glands, boilers, valves, and condensers in a steam engine can all be badly damaged by oil disintegrated by steam and boiling water. Marine engines were usually fitted with specialised separators to protect the delicate condenser. Elaborate precautions aren't so important or useful in a model. I like the smell made by steam engines: removing oil from the exhaust might spoil that.
          • Passing exhaust steam through the feed water will economise on heat but as you say you have arrange the plumbing to deal with water, lots of it, condensing in the pipework. You don't want to impede the exhaust or blow boiling water about!
          • Cooling steam in the feed-water before it goes into the condenser isn't a good idea because it reduces the vacuum and therefore the efficiency of the engine. No need to do it that way round because hot water from the condenser can be used to pre-heat the boiler feed.
          Several reasons for making a Stuart. They make a good looking working display, in which case puffing steam up a chimney with a blast pipe is attractive. Not a good idea to fit a blast pipe if your interest lies in making a working condenser to increase the power and efficiency of the engine. And a condenser will remove the energy needed to work a blast pipe, and the amount of visible vapour in the exhaust, spoiling the good looks of a steaming chimney. Using exhaust steam to preheat feed water will economise fuel but its not a good idea if the boiler is filled with an injector rather than a force pump. (Injectors work best with cold water.)
          Taken individually, lots of interesting ideas for experimentation, go for it. Applied together liable to be counter-productive.
          Jon Lawes
            @jonlawes51698
            A fantastic response, many thanks. That’s clarified a few things in my mind. So just directing the exhaust up a boiler chimney with no attempt to separate the water from the steam would probably be my simplest option. I plan to use a hand force pump to fill the boiler. Thanks for taking the time to respond, some very good info there.
          Home Forums Stationary engines Topics
