An oil grade commonly recommended for compressors is SAE 30. Machine Mart sell it, and on some of their packs in small print it also states it is suitable for petrol engines. Aldi also sell stacks of it from time to time.
The small direct drive piston compressors of around 8CFM with a 25 – 50 litre tank are pretty good for the small home workshop, but they are noisy and can't power most air tools very well as they require a lot of air. But they can be used for most other tasks and easily inflate tyres and can be used for paint spraying.
A few years ago I bought a Clarke Air twin cylinder 14CFM belt drive compressor with 50 litre tank from Machine Mart, a very good quality Italian made machine at a reasonable price that can fit under a bench. They are also slightly quieter and more durable than direct drive types.
For several years I have also been using one of Machine Marts rotary compressors with a 25 litre tank, I think it is called Shsss Air or something like that. It is extremely quiet, so is great for constant use in the home workshop, but they are now quite expensive and their air output is feeble when compared to piston type machines.
Last year I really pushed the boat out as I wanted to do my own blasting, so yet again off I went to Machine Mart and bought one of their Industrial Air compressors. This is 3 HP with a 14CFM belt drive pump and 150 litre tank, and this has a relatively soft and quiet exhaust note. These are built in the UK but appear to use mainly Italian components. A bit big for under the bench though, unless you have a big bench.
Apparently, it's the FAD ( Free Air Delivery) that counts, rather than just the CFM rating. The trouble is the FAD rating is rarely quoted.
Edited By Lathejack on 05/02/2015 22:46:07
Edited By Lathejack on 05/02/2015 22:52:21
Edited By Lathejack on 05/02/2015 22:58:37
Edited By Lathejack on 05/02/2015 23:08:43
