I've just measured the internal volume of a second head for my little 4-stroke engine. A sytri8nge of soapy water give 0.9cc.
The swept volume is a calculated 5.51cc, so the total volume is 6.41cc and the compression ration will be 7.12:1
I understand that the 'ideal' compression ratio for glow engines is 8:1, is this close enough for what is planned to be a low revving engine with a fairly weighty 'marine-type' flywheel. It is a 'square' engine of 0.756 bore and 0.750" stroke.
Other question, tappets are silver steel tempered to deep brown running in bronze guides. Cams and camshaft are one piece silver steel, what colour should I temper them to?
Thanks
