My Farm engine is complete, has spark, and some compression. I had read that these engines do not like too much compression, and I have read recently that you need “good” compression. The original plans had the piston stopping about 3/8″ down from the head, and there was little to no compression. I moved the cylinder and head so that there was 1/2 that amount of space, and it now shows “some” compression. It will not run, I can get a slight feel of firing if I use some butane as a fuel, but not so that it will run any more than 1 fire, and it is not enough power to turn it over 2 revs. It will not even fire with petrol or white gas.
With the spark plug out, I can flick the flywheel and it will turn over about 3-4 rev’s. With the plug in , the same flick will only turn it over about 1 1/2 rev’s.
Any suggestions, from anyone.?
I posted some of this under Beginners Questions, but didn’t get any responses.
