Compound Beam Engine
Home Forums The Tea Room Compound Beam Engine
  • #608300
    DrDave
      @drdave
      Down in Taunton last week, we found this beam engine in the museum. It had been used to power a local silk mill.
      I have not seen a twin cylinder, compound beam engine before. The high pressure cylinder has both a smaller diameter and stroke, compared with the low pressure cylinder. If I didn't have 20 other projects on the go, it looks like a good subject for a model.
      DrDave
        @drdave
        #608303
        Howard Lewis
          @howardlewis46836
          Some of the Cornish Tin Mines used compounds for pumping, although, by modern standards, ,pressures were low.
          James Watt used his patents to keep a hold, on engines in Cornwall, and elsewhere.
          It was Richard Trevithick who believed in using "Strong steam" ( 40 psi vs Watts 5 psi ), so compounding would have greater benefits with higher pressures.Wolff was an exponent of compounding, in Cornwall mine engines.
          #608306
            There are a few of the Woolf compounds about, Preston's has one if I remember rightly.
            More about this one on Grace's
            #608314
            V8Eng
              @v8eng
              Posted by JasonB on 03/08/2022 18:17:12:
              Another one at the London Museum of Water and Steam near Kew Bridge.
              Handy for us in the region!
              Easton & Amos
              Edited By V8Eng on 03/08/2022 18:46:48
              #608315
              DrDave
                @drdave
                Thanks for the link, Jason. I was not aware of that web site. Seems the compound beam engine was more common than I thought!
                #608320
                roy entwistle
                  @royentwistle24699
                  Bolton steam museum have at least one.
                  #608348
                  duncan webster 1
                    @duncanwebster1
                    A better method of adding a HP cylinder to a beam engine is to put it at the crank side of the beam pivot as in McNaught engines. This reduces the bending load in the beam compared with both the same side. A lot of one cylinder beam engines were retrofitted with a second HP cylinder .
                    #608351
                    Ramon Wilson
                      @ramonwilson3
                      Not forgetting this lovely example of an Easton and Anderson compound at the Forncett Steam Museum.
                      Always thought this would make for a lovely model project too
                      Bit late in the day for me now though
                      Tug
                      #608360
                      John Olsen
                        @johnolsen79199
                        The pumping engine at Western Springs in Auckland NZ is a compound. It actually has four cylinders and two beams, all connected to a single flywheel with a crank on each side. The HP bore and stroke are smaller than the LP, as with the engines above. Two pumps were driven, one from each beam.
                        The Hamilton beam engines in Hamilton Ontario are similar, except that there are two flywheels, making two separate engines with two cylinders each. Another difference is that the Hamilton engines have Watt's parallel motion where the Auckland engine has slides.
                        Actually once each cylinder would have been referred to as an engine, I'm not sure when that would have changed. The Hamilton engines are 1857-59, the Western Springs one was 1860's
