Posted by Oven Man on 07/06/2020 21:25:46:
Could it be the connection between the display and the PCB? …
Peter
+1.
I think this is the same unit.
I believe the display is a press fit to a zebra connector on the board; ie a connective pad, no wires or soldered joints. On mine the display's plastic locating pin top right just above the printed '15' has been glued, but the other – diagonally opposite, is free.
The top of the display has a bit of black tape that may be holding it together!
Although they work remarkably well in practice, zebra connectors needs a certain amount of pressure to work. I wonder if they might misbehave if knocked sideways, or be vulnerable to condensation? Maybe not – playing with an old digital caliper, I found the display remarkably robust and unfussy.
Try pressing the display on to the board gently, or releasing the mounting screws. (Duncan's unit misbehaves after being put in a proper box, whilst my neglected bare board still works! Maybe Duncan's display has been upset by the way the board is mounted in the box?)
PS I only know they're called Zebra Connectors thanks to this forum!
