As otghers say, don’t get too woumd up over exact tool angles.
Yes, what optises machining EN32 may be less than for EN16, but you are not trying to manufacture as many as possible, in as short a time as possible with maximum tool life.
You are, presumably a hobyist, so a few seconds more on the time for a particular operation is not going to be the difference between bankruptcy or not. The object is probably to make a maximum of six, not ten thousand.
Clearance is needed, to prevent the tool rubbing, but absolute precision in the angle is not vital.
For the sort of work that most of us do, the difference between five and ten degrees clearance will hardly be noticeable. AND, excessive angles weakens the tooling, ans shortens its life, since there is a smaller area to withstand cutting forces, and to conduct away the heat.
By all means, stone a SMALL radius on the edge of a tool for finishing. En excessive radius will encourage chatter, which is not what you need for the final cut.
HTH
