I’m trying to reply to a post by Keith on the Deleting Site Account topic, but rather than de-rail it, I’ll try posting here.
His post is italicised below as rightly, I can’t quote cross topics.
I have been looking at the site daily, just to see the comments and to hope for progress.
I am now convinced that a lot of the problems people are /have experienced is due to the machine and system they are using. I have a reasonably powerful PC with Win 10 and Firefox. All settings are as default and I have not installed any “clever” software. Reading a lot of the complaints about loading problems I have been confused at times, because I have not seen the same things. As a for instance, comments were made about flashing adverts. I had none of that. The banner add did move to the left after a time, but that was always so. At the moment I access the site from a Bookmark, clicking the green Forum takes me to Latest posts ,without loging in. If I read a post to the last posting and continue to scroll, it runs into the Latest posts again, which all seems pretty easy. I have no problems with the clear black type on a white background either.
I have yet to try to make a posting including photos, which was always my stumbling block on the old site, but I will try it later.
Keith
Keith, as you see from my previous post, loading can still be an issue as the Forum part of the site’s been down again for 40 minutes;
Flashing Adverts are still there to me, Samik & Cowells both have adverts where their display alternates between two images. I don’t like doing so on free to use forums, but I’ve enabled my Ad Blocker on this one, which is in no-ones real interest long term.
Latest Post was certainly an issue in it’s initial Temporary implementation, and is now much improved.
The issue I compiled earlier, where its use on different pages led to different results now seems to have been cured, so I too find it currently works well, though sometimes very slowly. I can also use the Blue Button whilst logged out, without causing me log-in/out issues experienced previously.
Black type on White is obviously OK for some, but not others, depending on any vision problems for the viewer; I’m finding it a bit of a strain.
There may well be problems with the displaying of posts on different devices; I’m broadly OK on a PC, which is sufficiently powerful to not be a bottleneck. Surely one of the specifications for this new forum, was that it should display in a useable format on all devices.
You’ll be pleased to know that posting images on here is a lot easier than the old forum, as albums are no longer required.
You need to do any re-sizing, or other editing, before uploading here.
Full pane width seems to be 800 pixels, so if you only want to part fill it, you need to re-size smaller.
The forum will handle larger photos etc, but seems to resize down to 1200 wide, and display at 800 to fill the display pane.
I covered this with quite a bit of explanation elsewhere.
As yet, the text-wrapping around photos doesn’t seem to be functional; the facility seems to be provided, but not yet implemented.
By all means tag me in as @peak4 and I’ll try and assist with photo posting if I can.
For basic image editing/resizing, please see my post about Fastsone Image Viewer
All in all, problems are gradually being resolved from what I can tell.
Must go, tea smells almost ready. 🙂
Bill
