Posted by Paul Lousick on 04/01/2023 10:40:34:
My first mill was a Sieg SX3 and used to mill most of the parts for a 6" Ruston Proctor traction engine. (refer my previous posts). It was a great machine but it starting having problems with the variable speed motor control board which I replaced. The replacement board also starting to have problems.
Our local supplier in Sydney no longer stocked Sieg machines and I sold it and bought a slightly bigger RF-46 type mill with a single speed motor and gearbox drive. Replacement control boards are expensive. Make sure that they will be available if you should need one.
Paul
Just to balance your observations, I believe that at the time you did say that you pushed the machine to its limits… which I would suggest you really meant that you pushed the SX3 to beyond its limits. Perhaps some of the pictures in your albums speak for themselves? I cannot say for sure. At the time, in response to one of your posts, I had said that the original SX3s had control board issues which were rectified, after which dealers like ARC added the machine to our range. This was a clear and long explanation at the time. So I am surprised to read that you continue to make this one sided comment on a regular basis. Whilst I respect your opinion based on your experience, my and thousands of hobby and ‘light industrial’ small workshop as well as ‘blue chip’ industrial users opinion defer from yours… if the machine is used within its limitations.
With regards to your local supplier in Sydney, I believe that they no longer sell SIEG machines based on commercial reasons rather than technical. This is a topic which no distributor will openly discuss… as they wish to protect their profit margins (interpreted in many different ways)
In the U.K., SIEG machines have a good reputation. They are well represented by Axminster and ARC who carry a good stock of spares. For SIEG brushless motor series machines, control board and motor issues are very few, and in most cases are due to user related issues…. And yes… I would say that wouldn’t I ?
It is wrong for you to continuously make the same comment over the years without balance. New users form opinions based on what they read, and it is only correct to present a balanced picture. Ken can read your post as well as mine and many other positive and negative posts about SIEG and any other machines and form his own opinion about suitability of a machine for his purpose.
Ketan at ARC.
