Collets
Collets
  • #173618
    Ian L2
      @ianl2
      I am not far off getting Halifax 10" (Atlas) lathe running. Looking to purchase some collets to fit milling cutters in place of the chuck. Do all MT collets fit I'v seen quite a lot but none mention the Halifax or Atlas l0" lathes. Some seem to have something that screws on the threads that hold the chuck, is this thread the same on all machines?
      Ian L2
        @ianl2
        confused what should I purchase
        #173634
        Enough!
          @enough
          Morses for courses – if it's designed for a certain size of MT collet, any MT collet of that size should fit. It's a standard.
          #173638
          Thor 🇳🇴
            @thor
            Hi Ian,
            The thread that holds the chuck differ from one lathe to another. The Myford ML7 uses 1 1/8 x 12 TPI (with MT 2 in the spindle), the 10" Atlas seem to have 1.5" x 8 TPI NF (with MT 3). You can get MT 3 collets that should fit the 10" Halifax.
            Thor
            #173640
            Bob Brown 1
              @bobbrown1
              I found that the collet chucks that fit on a back plate are the most versatile as it allows bar to pass through the head stock.
              #173642
              Ian L2
                @ianl2
                Thanks Guys
                Thor. In the link in your posting the collets mention Draw bar thread XXmm do I need to purchase something to pull and hold these in the lathe also how does one get them out?
                Bob. not seen any that fit on a back plate but will have search on internet latter.
                #173643
                Bob Brown 1
                  @bobbrown1
                  here you go **LINK** amongst others
                  Bob
                  #173644
                  Ian L2
                    @ianl2
                    Thanks Bob
                    #173646
                    Robbo
                      @robbo
                      Ian,
                      Further to Bob's post ,collet chucks that fit on a backplate can also be more accurate than those with a built in thread.
                      The accuracy depends on the chuck having a snug fit on the spindle register, the thread serves to draw the chuck onto this. With a ready made threaded chuck the register may not be the required fit. However, as the backplate will be machined on the lathe itself to fit the back of the collet chuck, concentricity should be guaranteed.
                      However, if you just want to try it out, get MT3 collets to suit the size of your milling cutters and make yourself a drawbar to pull them in to the taper.    Cheapest option while you decide if you need ER collets, and if so which size.
                      Edited By Robbo on 26/12/2014 10:34:40
                      #173650
                      Ian L2
                        @ianl2
                        Posted by Robbo on 26/12/2014 10:13:13:
                        Ian,
                        Hi Robbo
                        Just bit confused with what you mean with back plate machined on lathe itself !
                        #173651
                        John Haine
                          @johnhaine32865
                          When it comes to the drawbar, the easiest thing to do is buy a length of studding the right thread for your collets and saw off a suitable length. Use either a big washer or if you want to be fancy make a bush to locate the other end of the studding for the nut to tighten against. You do NOT want a very high tightening force on a morse taper, it just gets stuck! No need for high tensile steel drawbars or anything like that.
                          #173659
                          Bob Brown 1
                            @bobbrown1
                            Posted by Ian L2 on 26/12/2014 10:58:55:
                            Hi Robbo
                            With any back plate it is normal to fit the bare back plate the spindle and machine the chuck mounting face while attached including any register (step) to locate the chuck on the back concentric to the lathe spindle and square.
                            Ian L2
                              @ianl2
                              Posted by Bob Brown 1 on 26/12/2014 12:43:47:
                              Hi Robbo
                              So what I need is a back plate to match the spindle thread on my lathe.
                              #173664
                              OuBallie
                                @ouballie
                                I just knew I would be kicking myself soon after finishing the Marlow Drawbar fist
                                Completely forgot about them collects I have angry 2
                                A solution can blithering well wait until I need to use one indecision
                                Other half's voice just about gone due to yakking the past two days with family and friends and too much cocktail
                                Geoff – Peace and quiet for a while now angel
