Mine has a MT5, for which you get a short adaptor to bring it down to MT3.
(heres one with a centre in it)
The "Official" collet chuck goes on the L0 SpindleNoze and is massive. It's from Burnerd and has "multi bore" collets. looks like this below. Mine has the Key but there are lever versions as well.
The collets cover a big range but aren't quite as accurate as 5c or ERxx. The big advantage is that you can put long bars through the headstock… The disadvantage is the length it uses up.
They appear often on ebay, price varies a lot.
I would probably just by an MT3 ER40 and use a piece of threaded rod as a drawbar.
Hope this helps!
Mark
