Colchester student feed issue
Home Forums Workshop Tools and Tooling Colchester student feed issue
  • #426340
    Simon Grist
      @simongrist23300
      Hi All
      I have just joined the forum as I recently bought a Mk1 (1953/54) Imperial Colchester Student. This will probably be the first of many basic question posts!
      I have replaced the motor and added a VFD but I am having trouble engaging the sliding/surfacing feed, it will go into sliding feed only moving away from the chuck and when engaged in surfacing it just clicks and feels like something is worn or misaligned.
      Does anyone have a diagram of this type of apron? I can only find the later plunger type.
      The other issue I have is that the levers on top that change the gears seem to easily drop out of engagement, even under no load, is there something I can adjust to fix that?
      Thanks in advance for any help.
      Simon
      Simon Grist
        @simongrist23300
        #426416
        Phil Whitley
          @philwhitley94135
          http://manuals.chudov.com/Clausing/Colchester-Student-Lathe-Manual.pdf
          download this!
          There is a ball and spring clutch in the feed drive shaft which clicks loudly if the feed is jammed. can you post up some pics of the machine. I also have a mk1 roundhead student.
          Phil, East Yorks.
          #426556
          David George 1
            @davidgeorge1
            Hi Simon welcome to the forum. Where are you, it helps if you give your locality as people local to you know what is available etc. What are your interests there are many people on here from bikers to steam enthusiasts and countless others.
            David
            #427201
            Simon Grist
              @simongrist23300
              Hi
              I am in London in the UK, I got a diagram from the Colchester spares company and have now stripped the apt and the 2 feed shafts, it wasn't too mucky but the feed half nut is very worn. Just to be clear, should the feedshaft, the one with the keyway in it be turning all the time the motor is running? Anything I should look out for in the apron that would stop the power cross fed? I will post some pics in due course. Thanks
              #427211
              Ian Parkin
                @ianparkin39383
                The feed shaft will only rotate if the gearbox is set
                the only one that doesn’t matter is the metric/imperial selector
                and forward /reverse lever needs to be set to one or the other
                but the feed shaft will /should always rotate if the above is done
                Sorry just reread your post it will only run when the main spindle is turning
                motor turning no…it may have a clutch
                Edited By Ian Parkin on 03/09/2019 09:10:39
                #427220
                Simon Grist
                  @simongrist23300
                  Posted by Ian Parkin on 03/09/2019 09:08:32:
                  It doesn't have a clutch, so just to be clear, if the motor/chuck is turning, so should the feed shaft?
                  It all seems ok in the apron, no worn gears or anything, I think I need to assemble everything properly and then see if it all works. for some reason the interface between the feedshaft and the cross feed was not meshing properly.
                  #427247
                  Ian Parkin
                    @ianparkin39383
                    Yes when the chuck is turning
                    if the forward /reverse traverse lever is set
                    if the gearbox is set the lift up handle one
                    if the abcd levers are set
                    then the feed shaft should turn
                    set the imperial/metric lever and the lead screw should also turn
                    Do you have a gearbox for screwcutting?
                    Edited By Ian Parkin on 03/09/2019 11:53:43
                    #427425
                    Howard Lewis
                      @howardlewis46836
                      Don't know the machine, but in simple terms, I would expect to find:
                      1) A lever, or levers, which allow the rotational speed of the chuck to be altered.
                      The VFD almost makes this redundant for most work
                      2) A Lever with three positions,
                      One where the feed shaft rotates in the same direction as the chuck,
                      The Middle one where the feed shaft does not rotate, and
                      The Third one, where the feed shaft rotates in the opposite direction to the chuck.
                      This will decide whether the Saddle moves towards, or away from the Chuck when the feed, or the half nuts are engaged.
                      Another lever will allow the drive to be directed to the Feed shaft, or to the Leadscrew. WHEN the lever, above (1), is not in the middle location.
                      4) If you have a lever or levers with positions, A, B, C and D; these should alter the speed at which the Feed shaft or Leadscrew moves relative to the chuck.
                      NONE of these levers should be moved when the chuck is rotating. You may need to rock the chuck to and fro, by hand, to ensure full engagement.
                      You ought to contact Tony Griffiths at Lathes UK (Contact him through the Lathes UK website) to see if he has a manual, or if you can download one, for your machine.
                      You are in London, so there should be a Model Engineering Society within a reasonable distance of you.
                      Go and Join it! There will almost certainly be a member who is prepared to come and help you become familiar with your machine.
                      That may prevent you damaging either the machine, yourself, or both!.
                      The new WiFi keyboard and mouse have developed auto send, it seems!
                      Edited By Howard Lewis on 04/09/2019 16:36:46
                      Edited By Howard Lewis on 04/09/2019 16:38:43
